Hey guys, I'm thinking about welding on a Greddy/Trust sump extension while the engine is out of my car.
Has anyone done one and have any feedback on it?
Does it make engine refit a prick? Was it difficult to get it to lined up for welding?
Any feedback would be awesome. Very little info on here or the web.
Cheers,
Ewan.
Not too sure about the trust one but I had a Hi-Octane one welded onto my 26 sump and it doesnt have any clearance issues at all. I'm fairly sure the trust one would be the same but you should get someone who knows what their doing to fit it just to make sure it's in the right place.
Seems pretty cheap to me. $425 delivered.
Unless you just got a fabricator to make one and hope it works you're looking at well over $1000 change over for any of the recognised guys to do one (Hi Octane, Mercury, etc).
I'd do the cutting and just get it tigged somewhere that specialises in ali welding. Should only add $200 max extra.
are you doing the welding yourself???
if not, factor in that a welder will charge around $80/h plus cleaning and prep costs, materials for welding
alot of people including myself use the micks metal craft or hi octane extensions, they are a realy nice bit of gear
This is a good point, it'll need baking to remove oils etc from the metal and dont attempt to cut it up unless you know exactly what penetration gaps/prepping it'll need as you may very well make it harder to do. That price aint bad for that. Expect to pay 150 for ordinary job, 250 for baking prepping and welding.. Over 300 and they're having you
I went through the hassle of this not long ago if ur running a high vol oil pump eg tomei, the trust ext is shit you will be best off paying Racepace $1500 for their 9ltr sump includes extended pickup and fittings for drain/ breathers
If standard the trust extension is prolly an upgrade but waist of time in my eyes
Yep I brought one. Never fitted it, they don't hold that much more oil. And they hang down heaps low. I ended up getting a race pace sump. Haven't fitted it yet, but fark they a work of art
Hey guys, thanks for the info.
Uwissh- Not trying to be a smartarse but my post above yours is pretty clear about the welding. If I do end up doing it, I'll see how my alloy tigging skills are and I might make an additional side section to replace the baffled bit on the side on the std sump. I'll make it then get it welded on by a pro. I bought the alloy to do for all of $5 from the scrap metal joint the other day. It's 4mm thick so should be strong enough.
Where do you stop money wise??? That's always a consideration. I intend to track the car once I eventually get it back together but it might be 2, maybe 3 times a year max. I know it only takes one gut full of air to kill the whole engine but it's risk versus expense i guess!
I'm a poor man playing in a rich mans game.....
Ive heard with the trust sump sextension and a car that is a little lowered will hit into the apex on corners around the track. Id go with a racepace or high octane coz its a flat pan design
my bad, didnt read that part,
unless your really good at alluminium tig welding or tig welding in general i wouldnt even try to attempt it yourself, has to be done spot on, able to with stand pressure and also be pressure tested to ensure your not going to have any leaks.
as nismoid said, if you intend on tracking it then y would u do a half assed job, get it done correct 1st time n have some peace of mind
I would give it a go, im not the worlds best tigger, but i did mine out of 6mm, with 12mm plate for the sump plug area, just make sure you bolt it to a block when you tack it and outside weld it, then remove and inside weld it.
Edited by Adriano
I'm pritty sure, you gotta heat the sump up super hot before you start the welding. Just get a workshop to weld it. You want it done right, can u imagine doing it yourself and its not done right, pulling the motor out, fitting it, and than putting the motor back in only to find it leaks, or cracks on your first launch. The sump has a fark load of force going though it, if its not done right, you will break weaken it. Also make sure it's bolted down to somthing flat and left there to cold right down, so it don't twist or do anything crazy.
Someone has said (tuner or engine builder) that they've dealt with some dodgy "custom" RB oil sumps that have lunched acouple engines due to poor design. I assumed it was the Hi-Octane ones?
we made our own winged ext. like the Hi-octane ones, out of 4mm plate and made a swing gate baffle and ext pick up. had it welded on by a pro, no baking, etc, just a good tig welder. never had any issues.. its definately doable if your a half decent welder, just leak test it with the special dye ( forget what its called, but really thin stuff that shows the finest seep ) also we didn't take the diff out and no probs.
My current car has the Trust ext. and it does sit a bit low, low enough that I've worn off the bottom edge of the sump plug, and it doesn't hold much more than standard, but it has seen plenty of track and works.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
