Hey guys, I'm thinking about welding on a Greddy/Trust sump extension while the engine is out of my car.
Has anyone done one and have any feedback on it?
Does it make engine refit a prick? Was it difficult to get it to lined up for welding?
Any feedback would be awesome. Very little info on here or the web.
Cheers,
Ewan.
Not too sure about the trust one but I had a Hi-Octane one welded onto my 26 sump and it doesnt have any clearance issues at all. I'm fairly sure the trust one would be the same but you should get someone who knows what their doing to fit it just to make sure it's in the right place.
Seems pretty cheap to me. $425 delivered.
Unless you just got a fabricator to make one and hope it works you're looking at well over $1000 change over for any of the recognised guys to do one (Hi Octane, Mercury, etc).
I'd do the cutting and just get it tigged somewhere that specialises in ali welding. Should only add $200 max extra.
are you doing the welding yourself???
if not, factor in that a welder will charge around $80/h plus cleaning and prep costs, materials for welding
alot of people including myself use the micks metal craft or hi octane extensions, they are a realy nice bit of gear
This is a good point, it'll need baking to remove oils etc from the metal and dont attempt to cut it up unless you know exactly what penetration gaps/prepping it'll need as you may very well make it harder to do. That price aint bad for that. Expect to pay 150 for ordinary job, 250 for baking prepping and welding.. Over 300 and they're having you
I went through the hassle of this not long ago if ur running a high vol oil pump eg tomei, the trust ext is shit you will be best off paying Racepace $1500 for their 9ltr sump includes extended pickup and fittings for drain/ breathers
If standard the trust extension is prolly an upgrade but waist of time in my eyes
Yep I brought one. Never fitted it, they don't hold that much more oil. And they hang down heaps low. I ended up getting a race pace sump. Haven't fitted it yet, but fark they a work of art
Hey guys, thanks for the info.
Uwissh- Not trying to be a smartarse but my post above yours is pretty clear about the welding. If I do end up doing it, I'll see how my alloy tigging skills are and I might make an additional side section to replace the baffled bit on the side on the std sump. I'll make it then get it welded on by a pro. I bought the alloy to do for all of $5 from the scrap metal joint the other day. It's 4mm thick so should be strong enough.
Where do you stop money wise??? That's always a consideration. I intend to track the car once I eventually get it back together but it might be 2, maybe 3 times a year max. I know it only takes one gut full of air to kill the whole engine but it's risk versus expense i guess!
I'm a poor man playing in a rich mans game.....
Ive heard with the trust sump sextension and a car that is a little lowered will hit into the apex on corners around the track. Id go with a racepace or high octane coz its a flat pan design
my bad, didnt read that part,
unless your really good at alluminium tig welding or tig welding in general i wouldnt even try to attempt it yourself, has to be done spot on, able to with stand pressure and also be pressure tested to ensure your not going to have any leaks.
as nismoid said, if you intend on tracking it then y would u do a half assed job, get it done correct 1st time n have some peace of mind
I would give it a go, im not the worlds best tigger, but i did mine out of 6mm, with 12mm plate for the sump plug area, just make sure you bolt it to a block when you tack it and outside weld it, then remove and inside weld it.
Edited by Adriano
I'm pritty sure, you gotta heat the sump up super hot before you start the welding. Just get a workshop to weld it. You want it done right, can u imagine doing it yourself and its not done right, pulling the motor out, fitting it, and than putting the motor back in only to find it leaks, or cracks on your first launch. The sump has a fark load of force going though it, if its not done right, you will break weaken it. Also make sure it's bolted down to somthing flat and left there to cold right down, so it don't twist or do anything crazy.
Someone has said (tuner or engine builder) that they've dealt with some dodgy "custom" RB oil sumps that have lunched acouple engines due to poor design. I assumed it was the Hi-Octane ones?
we made our own winged ext. like the Hi-octane ones, out of 4mm plate and made a swing gate baffle and ext pick up. had it welded on by a pro, no baking, etc, just a good tig welder. never had any issues.. its definately doable if your a half decent welder, just leak test it with the special dye ( forget what its called, but really thin stuff that shows the finest seep ) also we didn't take the diff out and no probs.
My current car has the Trust ext. and it does sit a bit low, low enough that I've worn off the bottom edge of the sump plug, and it doesn't hold much more than standard, but it has seen plenty of track and works.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
