xntrq Posted November 5, 2012 Share Posted November 5, 2012 I know this may be covered already but I have only found conflicting answers. How can I tell if a motor is a RB25DE or a RB25DE NEO? Where would a stock R33 GTS-T turbo be located? What are the differences between the mentioned motors and the intake manifold, being a Y-Split or a single (as seen in most DETs)? 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/ Share on other sites More sharing options...
GTSBoy Posted November 5, 2012 Share Posted November 5, 2012 The pictured manifold is from a DE Neo. That's the only engine that had it. The R33 RB25DE and DET both had similar looking single inlet plenums and TBs. The DETNeo also has a single inlet plenum but has a different TB. It has traction control, so there is a whole extra butterfly and motor to drive it upstream of the main TB. The crossover pipe is therefore shorter. Neo DETs have an OP6 turbine housing. Of course these can be retro fitted onto older engines, so it is not a 100% proof of Neo-ness. A stock R33 turbo would be located on the exhaust manifold, in exactly the same place as any other twin cam RB engine's turbo. Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6611037 Share on other sites More sharing options...
xntrq Posted November 5, 2012 Author Share Posted November 5, 2012 Thanks mate, that was very helpful Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6611059 Share on other sites More sharing options...
webber Posted November 20, 2012 Share Posted November 20, 2012 As mentioned above, people retrofit and bastardise engines for all types of reasons. Head Casting Numbers, Most conclusive method for identifying heads. there will be a casting version number next to this identification number. IE. 5L7 3 would be the third revision casting of an R34 RB25DE. MORE INFO HERE Otherwise if you have just a block, look up the engine number and make assumptions based on that. FOUND HERE I have updates for both the register & the casting page. Just so lazy to type it all out. Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6633076 Share on other sites More sharing options...
Birds Posted November 21, 2012 Share Posted November 21, 2012 Mighty fine gearbox ya got there. Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6634631 Share on other sites More sharing options...
xntrq Posted January 5, 2013 Author Share Posted January 5, 2013 Bump with a new question. How to tell difference between R33 RB25DE non Neo to a Neo or DET? I have a hunch that I've got a DE sitting around but unsure if it's just a non neo DE or DET. To me they look identical but doesn't have a turbo exhaust manifold. Though when i bought this car in question, i found pieces if paper inside with PSI numbers and lap times, car had turbo timer and a racing clutch and pod filter. Everything says it's a DET but there's no turbo/turbo manifold so i think it's been converted to NA. Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6692265 Share on other sites More sharing options...
GTSBoy Posted January 5, 2013 Share Posted January 5, 2013 Nup. Turbo and manifold would have been sold off to someone or taken by original owner to use on another/next car. I think the R33s had different sized throttlebodies between turbo and non-turbo. Not sure what sizes they are. If the engine still has its cross over pipe, then the BOV on it will indicate turbo engine. If there is a water feed pipe from the beack end of the inlet manifold water plumbing around the back of the head to where the turbo would be, then that indicates turbo engine. Likewise the oil supply and oil drain back to the sump under the turbo. Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6692360 Share on other sites More sharing options...
jamind Posted January 12, 2013 Share Posted January 12, 2013 Neo has a plactic front cover and plastic centre cover, Im not 100% sure if the series 2 were steel though, Jamind Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-6703257 Share on other sites More sharing options...
Smokey_1507 Posted June 24, 2020 Share Posted June 24, 2020 (edited) Sorry for bringing up a old thread but I’m having trouble identifying what engine I have.. is it a neo or s2? It has a plastic cas for a neo, turbo is a 45v4 , 75t block, no igniter on back of the block for coil packs.. I don’t wanna start spending cash until I know what parts to buy.. cheers ? Edited June 24, 2020 by Smokey_1507 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934487 Share on other sites More sharing options...
KiwiRS4T Posted June 24, 2020 Share Posted June 24, 2020 There were a few "transitional" engines that had the Hitachi CAS but were not Neo engines. My theory is that you can tell by the ECU plug. The R33 is slim and has two rows of pins. The R34 (Neo) has 3/4 rows of pins. I used to know the colours of the plugs but maybe someone else can tell you. 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934495 Share on other sites More sharing options...
Ben C34 Posted June 24, 2020 Share Posted June 24, 2020 Vct connector is heaps different, pre neo has external Vct drain at front exhaust side, that should be reasonably obvious. Coil packs bolt in differently What are you buying? 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934496 Share on other sites More sharing options...
Ben C34 Posted June 24, 2020 Share Posted June 24, 2020 That's the Vct drain, if you have that you do not have a neo 2 2 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934497 Share on other sites More sharing options...
Smokey_1507 Posted June 25, 2020 Share Posted June 25, 2020 (edited) 2 hours ago, KiwiRS4T said: There were a few "transitional" engines that had the Hitachi CAS but were not Neo engines. My theory is that you can tell by the ECU plug. The R33 is slim and has two rows of pins. The R34 (Neo) has 3/4 rows of pins. I used to know the colours of the plugs but maybe someone else can tell you. Cheers KiwiRS4T, next time I’m back home I’ll check the ecu plug... the more I look at different pics of neo’s and s2’s I get confused at the differences!! 2 hours ago, Ben C34 said: Vct connector is heaps different, pre neo has external Vct drain at front exhaust side, that should be reasonably obvious. Coil packs bolt in differently What are you buying? Ben C34, I’m looking at service parts at the min, timing belt, water pump, spark plugs.. I’ve just got the car back from the painters and had an arch, side skirts, front and back bumpers fixed and painted.. I’ve just put a custom stainless exhaust on from the cat back ( sticks out a little too much, may take it back a little bit!) the next big thing will be injectors and turbo + link ecu and a tune to see what it puts out.. I’m not looking for crazy power.. it bothers me that I don’t know if it’s a neo but when I’m home I’ll check for the vct drain and ecu plug! i have kinked tension rods, rear camber arms, toe rods, traction rods ready to be fitted when I get back. the video it sounds like something is slipping in the engine, possibly a belt or could be bad audio but I heard something that doesn’t sound right ?♂️ IMG_0376.MP4 Edited June 25, 2020 by Smokey_1507 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934501 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 25, 2020 Share Posted June 25, 2020 2 hours ago, KiwiRS4T said: There were a few "transitional" engines that had the Hitachi CAS but were not Neo engines. My theory is that you can tell by the ECU plug. The R33 is slim and has two rows of pins. The R34 (Neo) has 3/4 rows of pins. I used to know the colours of the plugs but maybe someone else can tell you. This theory is flawed, especially if a moron (like myself) has put a R34 NEO motor into their R33 using the R33 loom & plenum Best way is to locate the front passenger side head drain, it's non-existent on a NEO. 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934503 Share on other sites More sharing options...
Smokey_1507 Posted June 25, 2020 Share Posted June 25, 2020 5 minutes ago, Dose Pipe Sutututu said: This theory is flawed, especially if a moron (like myself) has put a R34 NEO motor into their R33 using the R33 loom & plenum Best way is to locate the front passenger side head drain, it's non-existent on a NEO. Cheers I’ll check it out or get someone too ASAP!! Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7934506 Share on other sites More sharing options...
ADH_A31 Posted February 6, 2021 Share Posted February 6, 2021 On 24/06/2020 at 6:15 PM, Smokey_1507 said: Sorry for bringing up a old thread but I’m having trouble identifying what engine I have.. is it a neo or s2? It has a plastic cas for a neo, turbo is a 45v4 , 75t block, no igniter on back of the block for coil packs.. I don’t wanna start spending cash until I know what parts to buy.. cheers ? bro i’m looking for like this one intake manifold how can I fond one for my RB25de neo? thank you Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7946956 Share on other sites More sharing options...
Quincy Posted February 28, 2023 Share Posted February 28, 2023 (edited) @Ben C34 so does this mean i have a neo? I recently took out my CAS to paint as well and someone told me that it was a neo CAS but when i bought the vehicle (A31 cefiro) i was told the engine was just a Rb25 s2 Edited February 28, 2023 by Quincy Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7976263 Share on other sites More sharing options...
fletch rb30 Posted March 4, 2023 Share Posted March 4, 2023 Yes that's a neo head. They all have the oil drain un-drilled 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7976365 Share on other sites More sharing options...
Quincy Posted March 4, 2023 Share Posted March 4, 2023 @fletch rb30ooh so i got a neo head on a regular De s2 block? The guy who had the car before me didn't know much about what he had to be honest Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7976366 Share on other sites More sharing options...
GTSBoy Posted March 4, 2023 Share Posted March 4, 2023 49 minutes ago, Quincy said: ooh so i got a neo head on a regular De s2 block? Would be very unlikely. Neo combustion chambers are about 10cc smaller than the vanilla 25s, and the compression goes through the roof. Neos use RB26 rods and different pistons, with the differences being in the height of the pin and the shape of the crown. There is less dome, so they don't stick up into the chamber as far. 1 Link to comment https://www.sau.com.au/forums/topic/413126-how-to-tell-between-rb25det-and-rb25det-neo/#findComment-7976367 Share on other sites More sharing options...
