  • Replies 145
Posted Images
Hey does anyone know, i'm in the middle of complying a 4 door R32 GTS-T. Are the rules for side intrusion bars the same? Do you have to get bars just for the front doors, all doors or don't have to get any at all? Dunno maybe due to the pillar between the front and rear doors means that you don't need them? I'm guessing it's the same for all 4 door vehicles so has anyone who recently complied a 4 door vehicle needed to install intrusion bars?
  • 3 weeks later...
im in SA and complying a four door r32. all doors need bars, high mount brake light, fuel filler and unleaded tag, replace tread, baby seat points, return to stock struts, silencer for exhaust, replace pod for air box, return to stock steering wheel and most anoying is taking off the heavy tinting on the back 3 windows. i have a fun weekend ahead of me *nods*
I'm surprised your engineer wants the stock struts!?!?! he should be able to certify what you have got (I've got ZEAL coil overs in mine and they were fine!!!)
He also certified the pods! talk to your engineer....
Can i just say you guys are getting ripped off in the eastern states!!!
it cost us 150 bucks for an engineering certificate in SA...
so realistically you can get it all done for like 600 bucks!!! There are guys who offer it for that price over here!
all the best
Sure the certificate may cost $150 bux.. it's about that here... but in SA do you need to install intrusion bars in each door? install a fuel restrictor cap, change all seatbelts, and the other minor things? Each of these items is several hundred dollars each.
all the best
mate, you have it easy with the engineers cert! best I could get over here either Sydney or ACT was $450!!! would have cost me bugger all if I got it for $150...
Side intrusion bars are overrated...lots of compliance places just weld in square metal tubing and get them ticked off. things like fuel filler neck,..that is where you are getting ripped off also. Those things are like 30 bucks and then all they do is knock them into place..shouldnt cost two hundred bucks! and some schmuck payed 200 dollars to get his mirrors done.!!! what the?> take them down to a glass place and get them made up for like 20-30 bucks and glue them into place!
anyways im no expert but you guys are getting done i think
I agree with Luke - anyone paying $200 for mirrors and fuel filler reducer are being robbed!!! I didn't haev to do my mirrors, and the engineer gave me a sticker for the fuel door! no restrictor needed!
restrictor is needed in some states.. rather than just a sticker. Trust me, I tried. Like guys you can go on and on about "how everybody is getting ripped off" but some requirements are MANDATORY that are not in some states.. and of course how thorough your engineer in accepting things is another matter.
but there are different requirements for different states which require different costs (but no not $200 for mirrors).
JAS .. seat belts are very expensive yup for what they are. If you are lucky you can get some of a wrecked R32. I got mine for $100
Every State has different requirements. Perhaps a list of these requirements can be tabulated for each state and put in a new thread and made a sticky? It will save on confusion and the same questions be asked over and over.
blacky (or any West Aussie in the know)
If anyone knows about the updated 15year requirements (since april 4 2004);
Is a engineers cert. required in WA? I have been told that it is required, but you can take it over the pits and they will do the eqivilant of an engineers check/report if you don't have one for an extra charge.. (maybe this is only for stock-ish cars)?
  • 3 weeks later...
Thread's gone a bit dead, but i was wondering if a particular engineer was needed to sign off the compliance, or if a normal engineer (mod plater in qld) could do it?
Hi Neil
Anyone that is an automotove engineer will be able to certify your car and the mods. when you contact someone about it, just tell them what you require and the level of mods that you have.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
