Hey guys
Just a quick queory on what most people are using to remove their oil filters, as well as do you remove anything from the engine bay before they take it out.
Whilst ive changed my oil filter without any issues in the past. This time round it seems completely stuck in place, my oil filter wrench has bent whilst trying to undo it and I just seem to be cutting my hands apart because I cant get good enough access and keep scraping on things. This is in an R33 gts-t. I NEED SMALLER HANDS.
Cheers. Luke
jeez that doesn't sound right!
For next time; get a Drift brand filter as they actually have a metric socket on their head... if you can't get em out with a socket set; then something is seriously wrong...
As for your current situation i'm not sure sorry.... maybe spray the damn thing with WD40 then run the engine till its hot and loosened? I don't really know..
Assume oil is empty from the block - get newspaper down under the filter, long screw driver and a BFH (big hammer ;-)) and smash screw driver through one side of the filter and out the other. Twist off.
Not my favorite way - but I've been where you are before and it works.
Edited by SMOKEYC34
Multi grips can work well, or a better filter wrench. The screwdriver through the side as a worst case.
I don't use Drift filters anymore due to bad experiences but the K+N ones are cheap and have a similar hex adapter on the top...
lol. I bent my filter wrench. cuz i needed a slight angle to have any movement. Generally use Ryco filters in all my cars.
Might have a look in the shops tommorow and see if theres a better looking one then the flimsy thing I have now..
Haha I could imagine getting myself in a lot of strife trying to use a screwdriver.
By hand generally. I've just stopped putting them on stupid tight. At worst I need a rag to grip it. I've noticed that oil filters are much harder to get off hot than cold. Which sucks, because mechanics 101 says warm up oil before dropping it. If possible loosen it off a little cold before warming the oil up to drop it.
Even when I found a filter that was too loose (and tightened it up) it still didn't drop any oil.
Hey guys
Cheers. Luke
Hand Snug is all it needs
Screw driver punched thru the case all the way thru or it just rips the case open
A ratching strap filter wrench if you can find one works well?
Don't do it up stupid tight in the first place and u wont have this problem. I find if u do it up as tight as u can with one bare hand is more than enough, no leaks and just as easy to undo next time! Just my 2 cents
^^ this is what i had to do on my GFs avalon, overtightened by a mechanic and i had to put a screwdriver through it as a last resort, luckily the filter is on the front of the block
I use different methods for different cars. My car is some of that non slip rubber matting and by hand, the missus car is the same, but sometimes requires the screwdriver trick because it's hard to get to. Mums car requires the screwdriver trick unless i have welders glove handy, due to the filter being under the exhaust manifold.
Also make sure that if you do need to resort to bashing a screwdriver through the filter, don't do it low down enough that you're going to go directly into the threaded shaft that it screws onto.
I ended up buying the following tool from Supercheap for about $15. Needless to say. The angles fit in perfectly for the R33. Took longer to get it out of the plastic wrapper then it did to get the oil filter off.
If you need tools to remove the oil filter, you're doing it wrong.
Lube the seal, hand tight = easy removal.
I go by this theory, but as i explained in my post above, sometimes getting them off by hand isn't possible because of position (such as being under a hit exhaust manifold). I only ever put them on by hand
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
