Daniel Ricciardo is the Toro Rosso driver leading the race to step up to Red Bull next season, according to his team boss Franz Tost.
Earlier this month, Red Bull advisor Helmut Marko gave his support to Ricciardo, saying he is the "better" driver to replace Mark Webber should the 36-year-old leave at the end of this season.
Ricciardo has proven to be Toro Rosso's best driver in the opening stint of this year's Championship, scoring seven points to Jean-Eric Vergne's one.
Added to that, the 23-year-old has also outqualified his team-mate four out of five times while also securing the team's only top-ten grid position of the campaign.
"Well, performance is all that matters and you definitely can see that Daniel with 11 races more under his belt - which is more than half of a season - is probably in a better situation," Tost told the official F1 website.
"Right now he has the upper hand, which we have seen in Barcelona. But that is a snapshot right now. Generally I would say that both would fit into the Red Bull concept."
However, the team boss has mixed feelings about whether either driver is ready for the job.
"At the moment I would answer with a 'yes and no'.
"Both would have to demonstrate an exceptionally good second half of the season, because don't forget we are speaking about the World Champions, so the requirement profile is quite different to being with a team like Toro Rosso.
"But don't get me wrong, both are on a very good path and everything will depend on the next couple of months as to whether one of the two of them - should the need be there - qualify for Red Bull Racing."
http://www.planetf1.com/driver/18227/8715788/Tost-Ricciardo-topping-the-list
more good news!
New twin turbo v6 NSX sounds a bit cooler. Actually having said that, wasnt there a new NSX in the works with electric front drive and mechanical rear drive? What ever happened to that? Lol
coming 2015!
Honda could supply a second or even a third team when they return to Formula One in 2015 as their deal with McLaren is "not exclusive".
http://www.planetf1.com/driver/18227/8717061/-McLaren-Honda-deal-is-not-exclusive-
http://www.autosport.com/news/report.php/id/107462
I was thinking something more tacky, maybe something like a Carla Zampatti Laser.
So we've had the Williams-Renault / Senna revival
Now Martin needs to get Bruno's management on the phone sharpish so we can have the McLaren-Honda / Senna re-up for twenny-fifteen...
you want them to lose that badly?
:rolleyes:
I don't think it will be "crank it up" in the old 80s sense of the turbo cars. I don't know the details, but I suspect boost will be static, leaving ignition and fuel mapping to be tinkered. Pretty much like the cars of today, plus theres that bigger percentage of power delivered by kers.
Dead right but, they won't be throwing fuel out the exhaust just cause fans want it.
The only limit on the new engines is basically fuel. They are only allowed to carry a certain amount of fuel and it means they will have to be pretty conservative with boost and power if they want to make it to the end of the race. Hopefully they will hot them up to serious power then turn them down for economy but at points of the race lean on it for more power and speed...strategies will be interesting
So they are regulated to 15000rpm, and a specific fuel flow rate for 2014.
Whoever makes the most efficient engine that can run the most air for the specific amount of fuel wins. Lots of lean burn work going on I guess.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
