fcuk ets, bring on e85 and regenerative turbines
Cant understand why they havent gone to an ethanol/biofuel of some sort if they are trying to beef up their ecomentalist credentials. Too much like Indycar if they did?
Edited by djr81
they'd need near on double the size tanks to run full race without stopping if they used e85
Well they are limited to 100kgs which is what 140 litres? Back in the olden days before the last couple of years of the last turbo era they could carry much more. so another 20 or 30 litres to compensate shouldnt make much difference.
According to the internet:
1986: Fuel tank capacity limit was lowered from 220 litres to 195 litres.
1988: Fuel tank capacity limit was lowered from 195 litres to 150 litres.
Sux to be Felix Da Costa right now....but he has hurt his rep with a scrappy year in WSR. Hope fresh fish smashes JEV
Imagine being 19 and a GP3 driver getting pushed into F1
big jump..
Daniil Kvyat will feel overwhelmed like his bro Sergey Sirotkin..
i can't wait to hear the sky f1 guys try to pronounce those names. :D
They canned it due to safety but also due tot eh cost of carting all the gear from GP to GP. So dotn see re-fuelling coming back anytime soon...and the new regs with teh added weight of coolers etc and the further reduction of fuel tank size...they are really trying to put the ceiling on power based on economy and effeciency and their KERS power.
I susect that there wotn be much wastegate noise from these bad boys as that is wasted engergy and they weill be looking at that as a source of energy recovery somehow
Economy being the key word, plus sponsors do not like seeing crew members on fire regardless of their dancing ability, or visibility of flame.
Personally refuelling is ok by me, as it adds another system to the game and more to go wrong hence the word system, in that regard FFS bring back manual boxes, let thoses monkeys earn the big bucks too!
get rid of pirelli and bring back refueling.... best racing we will see this decade hands down!
people going full ball all race and teams running the gauntlet deciding how much fuel to run to give best advantage, I think it would show the men from the boys in the way of consistent race pace
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
