  • Replies 73
Mine is a White 96 R33 GTR V-Spec. Got it from compliance about 2 months ago now and am loving it. Was stock from compliance, have since added:
18x9.5" BBS LM with 265/35 Yokohama ES100s
Reconditioned APEXi T-max coilovers with king springs (FR 400lbs, R 225lbs)
Cusco Caster rod
Cusco rear camber arm
Whiteline Front camber kit and pineapples
DBA slotted 4000 series rotors FR & R
Came with dual APEXi dual chamber BOVs but will probably remove those in favour of a set of stockies.
Time to liberate some HP!
black 92 r32,trust tdo5  turbos,18 x 9.5 racing harts , here is a pic courtesy of merli
You will give me your wheels (waves hand, Jedi style)
awesome.
white 1992 r32 gtr but seems to have all the specs of the 1994 model (pull type clutch, electronic hicas pump in rear of car instead of hydraulic in engine bay etc
Hey Amaru, what does the pump look like in the engine bay / electronic Hicas pump in the rear? What does mine have?
I've got a White R33 GTR which was stock when I got it. (and basically still is) I've added a set of Nismo Clusters and centre gauges and I've got a Power FC ordered (hopefully I'll have it by Xmas) and a set of TE37's which hopefully I'll get in a few weeks.
as my name implies i can only dream about owning a GTR let alone a gts-t at the moment. i've only been for a drive in one slightly modified gts-t and the grin didn't leave my face for days.........buying my first skyline after months or years of slaving, that expression will be priceless.
I just sold my modded 93 GTST Type M. I lost money big time but I have the goal in sight, a 1989 GTR from Japan. still searching at the moment. have missd out on 3 so far. hope to find one this week.
but then its a damn long wait. I'm driving a 1979 Dato wagon at the moment.
I work damn hard for what I have and just hope that no one ever says you dont deserve it.
Have you ever had someone say to you or heard them say you don't deserve that car?
just interested thats all. I have seen some nice cars with wreckless drivers and i have thought that.
cheer
mark
Midnight Purple 95 Vspec
2530's
HKS FMIC
HKS Dumps
OS Giken Twin Plate
Sard 700cc Injectors
PFC + HC + Boost kit
HKS Cam gears
Full zorst
Z32 afm's
K&N Pods
Nismo Fuel Pump
Nismo Regulator
Cusco Catch Can
18" Impul Hoshino Racing rims
Defi Gauges
big stereo
etc etc.
315kw at all 4 wheels on 1.3bar.
Cheers
Brett
Mines a late model R32 GT-R (June 94 to be precise). White, with nismo sideskirts and nismo lower bootlid lip.
HKS suspension (very tough ride)
3 inch exhaust from cat back
17inch X 9 AVS wheels, Yokohama Grand Prix 255/40
Apexi Air (pod) Filters
Blitz Turbo Timer
Pivot Speed meter
HKS Cam Gears
Chip Torque Chip
Dyno: Max Power 233rwk @ 13psi
Quarter Mile: 12.84 @ 105.66mph
Drive it everyday and loving it!
I got a silver 1994 R32 GTR, its got ..
Tein type flex coil overs
Apexi pod filters
HKS front pipes
Trust cat back
DBA 4000 front brakes
WORK Termist 18x9.5 wheels
Rebuilt Standard turbo's with steel wheels
Apexi Power FC
HKS Cam gears
Cusco oil catch can
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
