Bnr34 Reverse & Fog Lights
Serpandrew
 Share
Thanks
I did wet sand, although with very fine grade... 1000 then 3000 grit.
Used Meguiars PlastX to cut/polish it, then Meguiars plastic UV protectant to seal it up. The UV protectant is actually really hard to source unless you buy that heavy duty headlight restoration kit.
Edited by Serpandrew
Thanks
You can either get the Meguiars heavy duty headlight restoration kit which comes with all the stuff you need, costs around $65: http://www.meguiars.com/en/automotive/products/g3000-heavy-duty-headlight-restoration-kit/
OR you can buy http://www.meguiars.com/en/automotive/products/g17110-headlight-protectant/ separately
I had bits and pieces from various kits with sanding and buffing pads which basically made up the Meguiars kit, you'll end up with the same results if you just buy the kit, you'll be able to use it more than once.
If you only want to get the protectant though here it is on ebay: http://www.ebay.com.au/itm/Meguiars-G17110-Headlight-Protectant-10-oz-/140709679655?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c2f35227&vxp=mtr
Might be lucky and find it on the shelf at autobarn. You'll definitely find the whole kit there though.
Yep, I actually sat my phone down behind the car recording to make sure its all working ok and its much brighter now.
Never knew it was so easy to take the lights out until I removed the number plate to clean behind it.
I was quite surprised when I found out that the reverse light requires a different wattage bulb to the fog light, they are the same fitment and size otherwise o_O
In NSW early 2013, for Sau Members, there'll be a Tech Night compliments of Meguiar's.
Sizeable discounts will be on offer - or just enjoy a free night with the club.
Nice work on those lights!
When I get soot on these from burning rich, I just wipe up with Malco Banana Wax. It's Nanotech action doesn't affect the UV sealant (whereas polish will).
Only in nsw? :(
Hi Andrew,
I would become a SAU.VIC Member and ask the Exec to...
Contact Matthew Bowen who runs these Club Nights (aka Tech Nights via SAU) to see if Meguiar's will run one in VIC?
Andrew Spira is sympathetic to these Club Nights too (and he's the Gen Mngr + owns a R34 GT-R VS2 Nur)
[email protected]
or...
[email protected]
Any estimates on when Terry? I'm quite keen on one of those for sure.
Thur 21/2/13 at their HQ in Silverwater.
Starts at 6 > ends sometime after 9. Includes eats & drinks free.
Includes 1x Demo of scratch/swirl removal + detail
Includes 1x Demo of C/F wrap on a panel.
It'll be in the Events thread next month or in the Members section.
That's the Prezzie's call. The complement limit is 35 people.
 Share
    • Yeah, I get that. I try to be as cost-efficient as possible with cars, and typically prefer to buy them at the bottom of their depreciation curve. I was looking at those Bilsteins too as they're roughly in the same price bracket as the BC's - lack of adjustability and being soft put me off, not that I want anything too hard. That's my issue with the Skyline, it's too expensive and it's reflected in my driving. I don't mind going full pelt as long as there's a gravel trap to catch me. Really, proper safety equipment is needed for total confidence. Well this just turned up for the BMW. I'll try and get the front together tomorrow and take some pics of the absolutely horrid rear end; perhaps I'll have a crack at the rear on Wednesday. I need to make the car drivable before the weekend as I'll be driving it over to London.
    • Hi SAU community  Wondering what my 93 Very RARE TH1 Blue R32 GTR VSpec is worth these days?? Build is fairly dated now All Mods are Compliance Approved  Runs RB26 done only 10000ks Greddy T88 done only 8000ks HKS Cam 1000cc Injectors Full Titanium Exhaust Nismo Intercooler Nismo Oil Cooler HKS Oil sump Tein Super Street Coils Cusco Sway Bars RAYS TE37 19x10.5 DYNO street tune makes around 700hp on 98octane
    • It does sound like a fuse considering the indicators work..I’ll triple check when I’m free and report back.    thanks for the reply.
    • no, the car was a manual 5 speed from the factory and still is.
    • While going through data logs late last week, I spotted a small issue with my WMI. My WMI starts to progressively inject at 11psi of boost. I'm using a 25psi cut in pressure switch on my WMI as an added safety and if the curve is linear, I should hit that 25psi on my WMI system around 13-14psi of boost.  As per my data logs, my WMI pressure switch only activates around 19psi of boost. This is causing my non WMI 4D map to trim for WMI. I'm presuming this is caused by the mechanical switch response time, injection curve not being linear or both.  I ordered a 2-10psi adjustable cut in pressure switch which should correct this. If this doesn't resolve it before my dyno appointment on Friday, I'll just remove the pressure switch temporarily and more than likely replace it with a pressure transmitter afterwards.    BTW Speedtek has yet to refund me.
