Yeah you're right Scotty. Double checked my figures today, and the injectors are maxing out. The FPR will get me out of the shit short term but I'll be getting it tuned shortly. You get the email from the HKS guys about the tune?
No mate, no emails about the HKS...
  • Replies 42
So Cihan should disclose all his tuning secrets so other tuners can copy his work? It won't happen... Too much time has been invested by him into the VQ25det now to just give the information away, I think my car has over 200 dyno runs on it already...
Not far to drive over Ryan for peace of mind...
Its not, but it becomes a pain in the arse to go back and forth every time I need a tune. Would rather work with someone local who is good and is interested in spending the time. There are a couple who have expressed interest, one with their own dyno.
It's interesting how this happens; your guy (and you) had to go through the learning process, and now there is more demand; the guys who put it in the "too hard basket" suddenly need a hand.
I don't doubt you have plenty of your own cash tied up in the entire process Scotty; no way 200+ dyno runs is a cheap process.
If your guy is good and interested; that is the ideal combination!
Maybe it would be worthwhile him investing his time and effort, so that he can hold himself up as one of only a small number of tuners that can work on the M35.
If you build it; they will come.
Exactly Dale, and that 200 runs isn't including the Emanage learning process before it.
I do honestly hope there are other tuning options and tuners in the future for the VQ25det, and if the guys at Nistune finally get on board we will all benefit. The HKS software is the best option available to us at the moment but there are so many things I would like to adjust that it doesn't have the maps for...
Agreed. Surely if your tuner is interested and is competent he doesn't need his hands held by someone that's done all the work...
Not for free anyway!
My tuner doesn't Jethro, it's the HKS guys who needed more information. The information they needed I don't think we could get from Scotty's tune anyway, as he's running non standard injectors.
Andrew now has these for sale on his web site: http://amperformance.com.au/product/miscellaneous/nissan-m35-stagea-performance-cold-air-intake-pipe
I will hopefully have a group buy price shortly for all those people who've contacted me.
  • 3 years later...
So after installing, good increase in response and power.
Need less throttle to get the car rolling and coasting on legal speeds.
Car seems to have more rasp in exhaust note and engine feels slightly less smooth in the rev range.
Does this sound normal ?
cheers
Wow what a difference the intake makes on stock tune.
I've put the power duct cover back on and blocked half the stock snorkel to reduce airflow until my tune.
Back to normal, engine smooth, better idle and less noisy.
How's that for home tuning !
Block off the f**king intake...
So is it possible this intake could cause the ECU to change timing ?
It feels like a late spark or something.
Still surprised I have rough idle and engine rev.
Blocking off power duct has helped a little but not much.
Just had another thought.
Maybe air is coming in through the join, which is after the AFM.
There's no physical seal on these,just metal to metal.
Gonna try and get a clamp around it.
A clamp probably won't help; but a solid application of tape around the join will tell you if you're on the right track.
  • 1 month later...
Yep these intakes DO leak between the middle join.
When it's fitted the two halves are pulled out a fair bit stretching the spring.
After doing a smoke test, it was visible.
So had it removed and sealed with silicone.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
