Sounds pretty close to mine (470kw, 20psi)...much the same spec but it is running E85 where as I'm only using 98.
Think I could maybe manage 500kw on E85, but after that I'm sure I would be seriously over speeding the 8374.
Lol i like the -9's on my old mans car but the 8374 is a good 600rpm more responsive from my experience :)
I have full boost before 3800 very happy with them won't change unless I want more power but 350kw is fine for me
What if you could have full boost at 3300rpm and make another 120kw on top of that? :)
Edited by Sub Boy32
Then I have other issues with longevity of parts as I track the shit out of my car, hence why I'm not fussed to go over 400kw
What can you do to that setup to optimise it?
The stock manifolds are fine, we both use them, I believe it ran pods as it was a 32. The exhaust wasn't small. It's pretty much a no expense spared car.
It was simply take the -5's off and put the EFR on. Belts it every way possible. Low end grunt, too end power, comes on earlier and back on sooner between gears.
If you could do a back to back between twin EFR's and the single to see the difference, I think that would be interesting but comparing it to what realistically is dinosaur twins (-9's,-5's,2530's,RS's, the trust things) the EFR would belt the shit out of them. This car that I went in yesterday was cracking gates at 4200 on a nugget 2.6 in second gear. -9's wouldn't do that yet the 8374 would supply Atleast another 100 kw of grunt. Between gear, forget it. It was like the gates shut at all. As soon as the clutch was let back out, it was making a anti social noise again.
Hey don't call the 26 a nugget!
Fair enough, I only take the car out to the track about three times a year and lunched the front diff one of the last times it went out......have since now put a Quaife ATB in it and have been out to the track with no problems other than my shit driving! Haha
.....I haven't run it on anything but 98, so the 470kw is on 98 :)
Thats great, 470kw on 98, easily over 500kw on E85 I would imagine :/
I am hoping for something similar, fully spooled around 3500rpm and 400awkw ish and I will be a happy camper :)
Edited by Nismo 3.2ish
  • Like 1
Update:
Engine is ready
Some pics
Nitto I beam rods and custom pistons with a higher pin to improve rod to stroke ratio
Also some new tein shockies, off to race pace for revalvimg, thanks to Aaron for import monster for sourcing
Just a matter of putting the engine in and fixing small bits and peices Pete
The pistons cost me a bloody fortune as they are a custom one off.
I was supposed to go to Perth next week for work but that trips been cancelled, might have it running by the end of the month :D
all good, just get your finger out, if I cannot drive mine, I can at least get some enjoyment out of seeing yours finished and that big stupid grin on your mush :)
So you had the pistons made special for your car, what is the difference, the pin placement ?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
