Do you mind telling me exactly what the setup you had previously was? I'm trying to find solid VE data for the RB engines and I'd like to use dynos (like yours) to determine where we are in terms of VE and turbo calcs and how this is applied. Using the defaults in Match-bot seems to make engines seem more responsive than they are in real life.
For your car and the first dyno posted, I came up with the following numbers so far: I simply can't get match-bot to work with your recorded boost, rpm, and power levels any other way than with these tweaked VE numbers, but they sure are close with these VE numbers! stretching from 72 out to 121 seems outlandish..but it makes the data fit and supports the maximum supported airflow of 68 lbs/min that this turbo is advertised at. I am assuming your engine had cams previously?
RPM - VE
3000 - 72
3500 - 72
4000 - 80
4500 - 100
5000 - 111
5500 - 117
6000 - 120
6500 - 121
7000 - 121
7500 - 118
8000 - 115
I do not know the effect that increasing stroke has on existing VE, but I sure would like to know. I'm hoping it increases at low rpms...because if not, Match-bot doesn't think much changes on the bottom end as far as boost threshold goes with these numbers. If you play with it, you will see that going up from 2.6L to 2.75L makes VERY little difference other than overall power. seems that VE drives a ton turbocharged HP calculations.
Sorry for attacking your thread with technical jargon, but I am trying to help you decide how much power you'll get out of the 8375. Sometimes going UP in displacement hurts efficienies, and resulting power. It may be better matched to a 2.6 or 2.75 than a 2.9
Edited by HarrisRacing
  • Like 1
I'm going for a very similar build. I guess I'm trying to figure out what cams and additional stroke do to VE tables for engines and I'm having trouble finding it all.
Hate to tell you but experience builds good engine combos not a computer program, there will be so many variables that the computer won't take into account that it will be never be accurate
RPM - VE
3000 - 72
3500 - 72
4000 - 80
4500 - 100
5000 - 111
5500 - 117
6000 - 120
6500 - 121
7000 - 121
7500 - 118
8000 - 115
Regardless of head, cams etc and all things being equal except for displacement, the larger motor will always produce more power everywhere in the curve than the smaller motor.
While a VE at a given RPM point may be lower, remember that VE is effeciency relative to volume being displaced. So while a VE may appear to be lower on the bigger motor for a certain RPM/Load point, it is still moving at least as much air as the smaller motor is for that same RPM/Load point.
Whether the engine is under boost or vacuum, more displacement per cylinder will equal more efficent cylinder filling. For a single rotation the larger motor is moving more gas. Without going into rod ratios or any of that other crap, this means a larger motor will pull more pressure differencial relative to the pressure inside the intake plenum than a smaller motor. If you do factor in rod ratios, the shorter rod ratio has benefits there for better cylinder filling too, due to faster acceleration of the piston away from TDC.
Even at the top end of the RPM range when the head is becoming a restriction to allowable airflow, and the power curve dropping off for the large engine will still be a higher output than a smaller motor would for that same RPM. Simply because it is moving more air through the restrictive ports than the smaller motor can, due to that increased pressure differential.
  • 3 weeks later...
Perhaps I was unclear.
Your logic keeps the assumption that the turbo isn't at it's max limit. I was studying match-bot when looking at my stroker and made the realization that these new "billet" wheels are adding airflow on top end and in Joey's case I would absolutely recommend him change the compressor wheel and let me explain why.
His cast wheel 8375 is only rated for 68 lbs/min of airflow. Any more than that and it's horribly inefficient and/or at overspeed (dangerous for turbo) and I'm sure is not recommended by BW engineers.
So using his old 2.6L setup (and some VE numbers I have reverse engineered), the match-bot for top end is as follows:
6000, 21 psi, 58 lbs/min, 542 HP
6500, 21 psi, 63.5 lbs/min, 570 HP
7000, 21 psi, 68 lbs/min, 600 HP (Max flow reached)
7500, 19.5 psi, 68 lbs/min, 592HP (max flow held, dropping boost)
8000, 18.5 psi, 68 lbs/min, 542 HP (boost still dropping to maintain max flow)
8500, 18.5 psi, 66.8 lbs/min, 488 HP
So this, to me, is a GREAT street turbo for a pumpgas 2.6L setup. It's sustaining boost to pretty dang high rpm levels and is just at the edge of the compressor map.
Data here
Now the SAME turbo on his new 2.9L:
6000, 21 psi, 65 lbs/min, 602 HP
6500, 19.5 psi, 68 lbs/min, 607 HP (max flow reached, dropping boost to stay on map)
7000, 17.5 psi, 68 lbs/min, 606 HP (Max flow held, still dropping boost)
7500, 16 psi, 68 lbs/min, 594.5 HP (max flow held, dropping boost)
8000, 14.5 psi, 68 lbs/min, 535 HP (max flow held, dropping boost)
8500, 14.5 psi, 66.8 lbs/min, 482 HP
So here you see that at 8000-8500 rpms the 2.9L is actually making LESS horsepower than the 2.6L at the SAME airflow limitations (turbo limits) This is because the turbo is falling off of the map at overspeed and I have to drop the boost to keep it in the safe zone.
Data here
Now the 61.4mm FMW wheel in his existing turbo on his new 2.9L:
6000, 21 psi, 65 lbs/min, 604 HP
6500, 21 psi, 70.6 lbs/min, 634 HP
7000, 21 psi, 76 lbs/min, 670 HP
7500, 20.5 psi, 78 lbs/min, 678 HP (boost lowered, max flow reached)
8000, 19.5 psi, 79 lbs/min, 622 HP (boost lowered, max flow held)
8500, 19.5 psi, 77 lbs/min, 561 HP (boost sustained, max flow dropped)
This is why I suggested that Joey look into changing out the cast wheel for the FMW 61.4mm compressor and housing that is found in the EFR turbo. This will allow his 2.9L to still be on the map on top end (thus making 30-80 HP more from 6500-8500 rpm over his existing cast 8375) since the FMW wheel limit is 79 lbs/min and loses NOTHING to the 8375 on bottom end with the turbine choices offered (hence why the billet wheels are slowly taking over).
Data here
I hope this helps clear up what I was getting at.
Patrick
PS - I would LOVE to see actual dyno results from this swap Joey!
  • Like 1
But I wanted to add...
My math all assumes that the increased stroke (and resultant piston acceleration speed per rpm), doesn't affect the VE table. This was the original question I had and lots of internet searching still didn't provide an answer. So yes, you do get more displacement, which should technically help everywhere, but what if the increased piston speed (vs. standard stroke) reduces VE at high rpms? Then effectively you've almost just moved the power band to the left (good thing really) and let the increased displacement of the stroke help in the bottom and mid rpm range (which again I like on a streetcar), yet lost a little VE at top end (which I agree still should make more HP).
Interesting, thanks for the post mate, obviously a computer isnt 100% correct but I see what your getting at.
Must remember One of the benefits of the stroker is that I do not need to spin it to 8500 anymore as the power and torque band is now wider and boost comes on earlier. Also cam gears will be dialled in for response so it will actually fall over quicker which is fine as I won't be spinning it much past 7500. Good for reliability :D
I wasn't aware that its a straight swap for the FMW wheel!??
and a back to back would be great! I'm just sick of spending money is all. I also have the option of going to a larger rear housing which would allow boost levels past 25psi.
But let's see what the final result is, it didn't really fall over too much on the last tune and there is a few things I have done to help improve flow..
Time will tell!
Time will tell!
I think it is just the FMW wheel and front compressor cover. I think both of these parts are relatively cheap (likely less than $200 total).
You know (based on our previous conversations here) that I was leaning toward the 8375 cast for my build as well since they are $600 US and they would be a great bottom end pump gas setup for a stroker build. I did go overboard on the 8374 EFR simply because I picked one up for $1700 US shipped and the financials just work after pricing in wastegates, FMW turbo, etc. Bad thing is I'm stuck with the .92 IWG housing now unless they release different IWG A/Rs in the future.
Why don't you change rear housings? I'm sure somethring could be worked out.
After being in a stock 2.6 with a 8374 1.05 AR rear, I'm not sure if the 0.92 is necessary. Definately not on a stroker IMO.
Tell us more!! Wait...do more...get us video!!!
I'm going for a similar setup to Joey's...bottom end monster. I like the simplicity of the IWG model instead of 2x external gates, dumps, etc. The excessive "Octopus humping a hair dryer" under the hood just wasn't what I was going for on my car.
so really your not going similar setup. Just a stroked bottom end
I was referring to the small(ish) cams, stroker, smaller AR turbine, etc. Looking for nice street powerband. I would say I'm heading in the right track as opposed to super-high-revving. long-duration-cammed, 2.6L. And I don't like the RB30 block idea with the taller deck, etc with the funky fitment issues.
  • 3 months later...
So engine has been in for a couple of months now, a few issues needed addressing such as fuel pumps and making a few other things fit
Everything is hooked up and ready for tuning,
Also fitted the AO rear brembos
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
