Hi all,
I've just about completed what I consider to be an entry level track setup on my 32 GTSt. Just wondering whether this will be enough for the car to handle well enough for a beginner driver. All comments welcome...
BC Racing Coilovers (8kg front, 6kg rear)
Whiteline subframe bushes
DBA 4000 front rotors
Optima Front pads
HICAS lock bar
Brake master cylinder stopper
Remapped ECU with Nistune chip
Car puts out 222kW on 18psi with all supporting mods and is tuned for track work.
Cheers
just drive it however it is now, as long as its in good mechanical condition of course. You don't need to complete a list of mods to enter a track day. I've driven my stock auto Soarer at a couple of track days and the only thing done to that is a set of lowered springs. Its just as much fun to punt around the track as my 200rwkw 180SX was with all the mods...
See plenty of people tracking much less car than that, personally, a Camira (it was a rally car, but it had SFA done to it) and a bog stock Mitsubishi Starion. Just get out there and enjoy it, some form of oil control (not sure if rb20s have the same issues as 26s) and cooling would be a great idea for the longevity of your engine though.
Hi all,
Optima Front pads
HICAS lock bar
Cheers
So reading this you have already done these mods?
If thats the case i would change the fluids and add in something to keep an eye on temps and oil pressure if you can then go your hardest, heat in WA can be tough on car so monitor it and you can always take an extra cool down lap if it is a problem and add further mods as you go along.
Good point. Gets hot up here in QLD too. The track day I did last week was 32degrees at the track. I was doing 2 or 3 cool-down laps to get the engine temps right back down and give the auto a rest.
I've been using thermocouple temp gauge/alarms on all my cars for about the last 3 years. Having audible alarms means you don't need to constantly stare at a gauge. Good for everyday cars too - who really looks at their temp gauge constantly on a highway run? You can set the alarm levels to whatever you want. Being thermocouples, they still read a proper temperature if you've lost coolant, whereas normal gauges just don't work if they're not immersed in coolant. Quick and easy to hook up, with no need for those dodgy in-hose temp sensore adapters which add in 3 extra potential points of failure. And can control thermo fans as well, with user defined on and off temps.
32 GTS-t at that level, you don't need an oil cooler unless your sprints are 25 laps plus (even if the ambient is well into the 30's). Just over-fill it by one litre and she's good to go.
Mine is living proof, using Castrol Edge 10W-60.
Edited by Marlin
What about a harness. I've done one track day in my XR6 Turbo and it was horrible trying to stay seated. I'm about to take my GTR on the track for the 1st time early next year and was wondering how much of a difference a harness makes?
The falcon seat will suck teh balls in comparion to the GTR one.
But a proper seat and harness is a whole other deal.
depending on rims/tyres a power steering cooler wont go astray either
hhhhhhhhhhWhat?!?!?
No need. Just stop topping it up after the Resevoir has a spit and gurgle. It'll find it's own level.
None of this is ground breaking info here.....
Cheers mate. The gtr seat is a shit load more supportive than the old falcon one. I guess i'll try a day with it standard and if i find i need more i'll grab a seat and harness combo.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
