Hey guys,
I'm looking for a stock rb25 turbo, prefer an R34 OP6, but will take what is available and in good condition. Not looking to buy for another few weeks yet, but thought I'd post up now.
Thanks.
I have a 33 (2IU) stocker that's in decent condition if you can't track down an op6
Sweet! That could be the go. How's the shaft play? Any idea how much boost it's run?
I've just bought an rb25det motor with a few fun bits, minus turbo. Was running GCG highflow before. I am going to run stock turbo just until I can afford to upgrade then retune the ECU, but might be on there for 6-8 months.
Never ran more than stock boost (7psi) and there's minimal shaft play. Was running fine before I removed it.
Can anyone help me out with this panel and vent in good cond.
Silly me a whiles ago decided it was a good place to put a boost gauge (which it is) but now I want it back to OEM look.
Thanks in advance.........oxox
Yes good when stationary and you move a little to see it.
As soon as your driving it's pisspoor ! and when I want a quick glance whilst going for it - it's f**ken usless
and yes the interior is immaculate (in Bob's ADM). Good to use for refrence pic too :)
I have one somewhere as iv got a gauge there. I was going to put it back in as my new racepak dash can display boost. Wait what? :P
If you want it ill swapsie it for a cluster surround + cash your way if you find it. Either way you know where i live and have my number :)
It should do. Ill get a spare to modify anyway, ill make the bloody thing fit :P
I want to position it so i can still see the fuel gauge. If i cant its no biggy, ill just have to use a button to reset fuel used and display that.
Just checked my shaft play today, A lot worse than I though, defs going to need to change turbo pretty soon.
Am I able to get away with an R33 turbo? If anyone hears of anyone R34 OP6 turbo for sale send them my way.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
