Spent all day fixing a mates computer that he just got. Put win7 on it instead of the shit known as win8.
Just FYI: new Win8 computers/laptops have their BIOS locked. Pain in the rear to put win7 on and fix all the issues. They make is so frustratingly difficult.
Anyway it's all sorted now. I'm having a fking beer. I have never in my life had as much pain to get a computer going as this one (and this was with two qualified I.T technicians working on it). I love new technology. :domokun:
LOL thought was wasteland..... hahahahahahahahaha
Any chance you can get one of those "Qualified I.T. Technicians" to point you to a more appropriate thread for your above Rant? :P
  • Like 1
Looking for R33 full body kit. Preferably black
Found this one on this random facebook page... https://www.facebook.com/photo.php?fbid=10152432343505278&set=gm.578108035601080&type=1&theater
Dunno how keen you are. Thats in wodonga though
yeah i saw this a few weeks ago when i didnt have the spare money but i might see if he still has it. thanks for finding it for me man :)
  • Like 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
