On ‎28‎/‎4‎/‎2017 at 9:53 PM, Sinista32 said:
Did you get one Andrew?
Oh hey, time for an update.
Yep, my transfer case was toasted, so I got one from Trojan, it's all in and working and GODZILA is back on the road!
Thanks for pointing me to that guy, it was actually surprisingly difficult to find a good transfer case at short notice.
  • Like 1
  • 2 months later...
  • 3 weeks later...
Hi all, chasing a few R32 bits if anyone has them
I'm after a R32 Gts-t passenger side indicator (orange or clear type)
R32 Passenger side headlight (H3C projector type)
R32 Passenger side guard (preferable factory dark blue but open to other colours)
Possibly some sort of front bar, be it factory, GTR or aftermarket
Possibly a factory front reo, either cut or un-cut
Possibly a complete passenger side quarter panel
(can you tell I binned my car?)
Thanks!
  • Like 1
  • 4 weeks later...
  • 4 weeks later...
  • 9 months later...
  • 2 months later...
G’day all. Does anyone have an RB26 valley centre cover/spark plug cover they’d consider selling? Has to be genuine, ideally with the orig’ branding, but other than that can be a bit ratty(it’s getting painted)? Send me a message on oh four one four, four hundred and eighty four, one 7 uno!IMG_3583.jpg
Pic for illustrative ideas!!
G’day all. Does anyone have an RB26 valley centre cover/spark plug cover they’d consider selling? Has to be genuine, ideally with the orig’ branding, but other than that can be a bit ratty(it’s getting painted)? Send me a message on oh four one four, four hundred and eighty four, one 7 uno!IMG_3583.jpg.b05defc571779dc7700145c837731639.jpg
No need any longer: I found one!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
