In the turtle wax kit I use it comes with a sealant in case you have to really cut back the plastic but I've never had to use it. The cleaning compound works fairly well. Could be worth a try.
Thanks guys, I went to super cheap and got a repair kit, took me about 15 minutes for both headlights and am happy with the results, I am not sure how long it will last though
Risky business with plastic headlights, and with r34s ridiculously expensive headlights there is no $$$$ for error :P
More SkyHatch Gumtree Goodness. :D From Tasmania this time.
Fitted Steering wheel this arvo and another 3 months Rego.
from this
to this.
oh and yes, the gearknob has changed again to reflect a few little friends I have met since purchase.
  • Like 2
Cheers guys. :)
The original is the same style wheel that the R31 Wagz had but the newy is an N13 SSS wheel I believe.
Looks and Feels much nicer and was an Absolute Bargain!
Pics when done
What year model did you get Troy ?
I saw what looked to be the most current R yesterday and I think I like the previous shape better.
New one looks squat and more like a Velocitor
Fitted the Haltech
Started it, goes broom brroom
posted on SAU about it
Mmmm, sounds a bit crook, should be BRRROOOOMMM BRROOOOMMM , did you get the right Haltech
Edited by TT350GT
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
