Every company that makes the collars has their own method and measurements that they're working off so will all vary to a degree. It only needs to be a few thou different to make the difference between being an interference fit and "loose".
In an ideal world you would take your intended pump drive inner ring to the machinist and have him match the new crank collar to the inner ring to be a perfect fit. Even to the point of having to slightly heat the oil pump inner ring when re-installing the pump it so it slides on. This would potentially cause issues though when time came to remove the pump as it could get pretty well locked onto the crank collar once a bit of rust formed. Theoretically you shouldn't have to pull it apart too often though.
That's entirely my own logic so feel free to rebuff!
I've started my rb30/26 build (well sorta) and I'm going stock (new) 26 oil pump but with reimax billet oil pump gears/nitto crank collar
90% street driven we don't see the need for anything more
Yes. The N1 pump has smaller gears than the standard pump.
I can't recall the actual measurements but it's about 5mm or so difference.
You need to order the right gears for the pump you have in other words.
Spend your money on a good set of pistons with good rings that will actually seal...The RB oiling problem is 90% excessive crankcase pressure (too much blow by) and 10% too much oil flow to the head. You need to fix the problem at the heart of it all!
Putting on extra crankcase breathers is only another band aid fix. Which does work fine though. If your engine is already built or bought, then adding the appropriate breathers is your only real choice.
exactly, the problem isn't getting the oil to the sump it's letting the air out and in an ideal world piston rings that seal perfectly would be lovely but not everyone can afford them, so crank case/sump breathers are a good solution/alternative
given the design of the head (26 anyway) the "rear head drain " is more just a breather and even though some oil does go down it the air it releases from the bottom end is its main benefit
as Shoota_77 has said the gears in the stock pump are bigger and IMO would be the choice of OEM pumps if you are going to change the gears to the Reimax ones and shim it for a bit more pressure
Can anyone confirm if the cp piston kits come with optional upgraded "high boost" piston rings??
When my mate did his rebuild they asked if he wanted the standard rings or better ones for extra $150 or so
I cannot find much info on these different rings
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
