Ok, well this has been long overdue but now that I have finally some time (and if the world doesn't actually end) and that things are coming together I thought it would be be best to give you guys a look at what I am doing.
First of all a little bit of history.
The car I have is this
It is a late model 1994 R32 GTR which I purchased in 2003 (feels like many light years ago it :D ) and it has evolved mildly as the years have gone by.
Previous configuration of engine was a follows:
Standard Bottom end
Tomei Sump baffle plate
Tomei poncams (type A) 256deg lift 9.5 in and 260deg ex lift 9.5
N1 Oil Pump
N1 Water Pump
Nismo turbos
Sard 550cc injectors
Twin Plate direct clutch
Greedy turbo / inlet piping kit including
2 x RB25 A/F Meters
Cooling Pro Intercooler 600x300x100mm
Cooling Pro raditor 42mm dual core
Gates Timing Gears (not dialed in)
Gates timing belt
Trust clear timing cover
Cooling Pro Oil Cooler (not sure what size but that big)
CES Racing dump pipes (short version)
Aftermarket exhaust (know idea what type but it is loud!!)
Aftermarkert adjustable suspension (whith HKS coilovers)
Pivot speed meter (registered 256km top speed once :woot: )
Chipped CPU tuned on shell optimax (at the time)
Engine power over 310rwk at 20psi (with boost dropping due to shyte wastegates) and quartermile 12.4 @ 192kmph
Anyways, I have a huge passion for the skyline GTR and the new Nissan GTR but the RB26 is an obsession for me.
Any GTR owner knows it is that this is an expensive hobby (understatement :dry: ) but to me this car is my mistress and yes I am married :yes: to a beautiful and understanding wife and have a beautiful daughter together (who are truely my number one passion)
Anyways, the car has done a fair amount travelling as it was my daily for some time although I a Ford Falcon POS station wagon these days.
I knew that the car would need to be rebuilt so I had started to collect the necessary parts for it after some guidance from my mechanic (who is well known on the Gold Coast)
The ideas was something like this:
Brand New N1 Block
CP 86mm pistons
N1 Oil Pump (or better)
New R33 GTR crank
Reconditioned Head
Garrett GT2860-5s
Bigger injectors
Apexi PFC
New Exhaust
So I had been gathering all these over the years but recently I cam across this
Must admit that after looking at the specs of this I could not beleive my eyes how good this was for its price considering you the cost of a brand new N1 engine from Nissan.
The specs for this are as follows:
COMPONENTS USEDCYLINDER BLOCK ASSEMBLY – NISSAN OEM N1 REINFORCED
CYLINDER HEAD ASSEMBLY – NISSAN OEM
PISTONS – TOMEI FORGED
CONROD – TOMEI FORGED H-BEAM
CONROD BEARING – NISMO F112 MATERIAL + NEW OVERLAY PLATING
MAIN BEARINGS – NISMO F112 MATERIAL + NEW OVERLAY PLATING
CAMSHAFT – TOMEI PONCAM Type-B
TIMING GEAR – TOMEI ADJUSTABLE PULLEY (IN/EX)
TIMING BELT – TOMEI STRENGHTENED
HEAD GASKET – TOMEI METAL
WATER PUMP – NISSAN OEM N1 SPECIAL (High Flow Type)
OIL PUMP – NISMO (WITH REINFORCED GEAR)
OIL GALLERY ORIFICE – TOMEI
OIL PAN BAFFLE PLATE – TOMEI
SERIAL PLATE – UNIQUE WITH TOMEI SERIAL NUMBER
※ All the other parts used that are not mentioned above are NISSAN OEM parts.
SPECIFICATIONS
DISPLACEMENT – 2597cc
BORE SIZE – Φ86.5mm
STROKE – 73.7mm
BLOCK TOP DECK CORRECTION – Minimal
PISTON CLEARANCE – 0.055mm
CONROD BEARING OIL CLEARANCE – 0.045~0.055mm
MAIN BEARING OIL CLEARANCE – 0.045~0.055mm
INTAKE CAMSHAFT DURATION / MAX LIFT – 260°-9.15mm
INTAKE VALVE TIMING CENTERLINE – 110°
INTAKE VALVE CLEARANCE – 0.45mm
EXHAUST CAMSHAFT DURATION / MAX LIFT – 260°-9.15mm
EXHAUST VALVE TIMING CENTERLINE – 115°
EXHAUST VALVE CLEARANCE – 0.38mm
COMBUSTION CHAMBER VOLUME – CORRECTED
HEAD GASKET SIZE – Φ87.0-1.2mm
COMPRESSION RATIO – Approx 8.4
FRONT FINAL GEAR RATIO – BNR32/BCNR33 4.111
Needless to say that I could not resist to miss this opportunity and after one phone call with Kyle from Hi Octane Racing I think I became one of the last person to procure this limited edition Advance spec engine :banana:
Last week I recieved any email from Hi Octane stating that my engine would arrive by the end of this month
So my initial idea of the N1 block and 86mm cp pistons went out the window as this engine is going to be interesting to say the least.
Since I had the idead of replacing the nismo turbos my car has been off the road since December 2010 and currently looks like this
Actually it looks even worse now as it does not have the coolling fan and a/c piping etc.. as I have been resotoring the car as follows as follows
Dirt and dust that has build up behind the I/C
All cleaned up
Paint stripped, sanded and with any rust removed and then cleaned with degreaser
All wrapped up and ready for respray.
Resprayed with rust proof primer and then will be fnished off with Holts Autospray color code DSSB01 (the closest color to Nissan Cristal white 326)
It is getting a bit late now so will end this introductory post, but for all of those out ther who love evolution photos here is an early Christmas present for you
CES Racing dump pipe removed
CES dump pipe cleaned out, sanded and painted in VHT Hi temp proof black paint
OEM timing cover paint striped, sanded and prepped for some new painting
As always, preparation is the key to almost everything especially when it comes to painting
Just another photo before painting.
All primed with anti-rust primer (not that alloy really needs it)
And finally with VHT Wrinkle red spray paint (and yes this was all done before I have acquired the new engine and will be available for sale later on)
P.S. Tomorow I will give a breakdown of the ancillaries that will be joining the new Tomei advance spec engine :thumbsup: so watch this space
Ok as promised here is what will definately be going in my new engine
A box! well that's not going to go onto my engine now is it :no: question is what's in the box?
Another box....c'mon now....but there are numbers on this box what could it be????
Enought teasing, yep brand new Garrett GT2860R-5 which were acquired from my good friend Andrew at Kudos Motorsport
These should do the trick for what I want which is approx. 600hp at the crank.
Made in Japan I like it :yes:
Rear exhaust housings
Since I am chasing 600hp at the crank or 400kw at the wheels I have been thinking about the following ancillaries:
1,000cc injectors but what type i.e. HKS, nismo etc...(forgot to mention yesterday that the car already supports a Sard uprated intank fuel pump 280lph but is it enough?)
Apexi Power FC (non-d-jetro and will explain why later)
OEM exhaust manifolds ported (photos will follow shortly)
Dump pipes - CES Racing long versions
Front pipes???
Exhaust - should I be getting something bigger than what I already have???
Anyways, I'm certain there other things to consider so any input is more than welcome.
Ok, today I fnished porting one of the OEM exhaust manifolds which used to look like this
I then superimposed an exhaust manifold gasket (this one is a Tomei metal one) and marked the outlets with a permanent marker
Then I went to Bunnings and got the following
Why you say? well it is simple, I do not have an air tool and the above fits directly into any electric drill (like a drill bit does) and although it costs $69 a peice it is worth its weight in gold and will save you the labour costs of someone else doing it for you + if you are like me you get the benefits and pleasure of doing the work yourself :miner:
The results....
I also purchased a Dremel tool from Bunnings as I think that it will be very useful in the future
and you get to this with it
Sanding the rough bits left over after being ported
Top ones are ported and the ones below are standard OEM ex. manifolds
Here is a better photo that compares the ported manifolds vs standard ones.
Ok, now I know that there has been quiet a debate regarding standard (low mount) exhaust manifolds vs stainless steel items i.e. tomei / HKS manifolds but IMO if you are going direct replacement for low mount turbos keep your OEM exhaust manifolds and port them (or get N1 versions)
They are more durable e.g. not subject to cracking and will retain the heat better than most aftermarket stainless steell items which will help the turbo. This will also save you a bit of $$$ that you can either re-invest, give it to me :D or buy something else towards your build.
I have also ported the turbo exhaust side which used to look like this
but now look like this
They are actually a fair bit larger than the -5's turbo charger exhaust housings
May have to do some port matching here.....
Edited by Ants
Nice build thread mate love the car. Apart from actual engine specs you're heading towards the same type of setup I have just put on my 32. Shame it's not running yet so I can't give you any helpful advice on what I could've done better lol. Anyway will be looking forward to more progress reports and hopefully I'll get mine up and running by the time your finished lol.
Okie dokie,
The other day I decided to give the front reo bar some TLC as it was starting to get rusty and used to look like this
It had been cut to make to provide more air flow to the impul front bar that was initially on the car when I had purchased it. Is it road worthy.... I don't think so. So, I will be welding some plates and if that fails well I will just source an N1 reo bar.
Rusty bits on reo bar....better treat it now before it gets worse
Rust bits remobed with electric sander
The left hand side rust removed.
Then rinsed and dryed and then resprayed in hi temp 3M mat-black spray paint can.
Just another shot of the resprayed reo bar.
Edited by Ants
Some nismo bits that will form part of the engine
Nismo engine mounts and nismo low temp thermostat
The real mccoy.
There are other Nismo items which have not arrived yet but will post pics as soon as they arrive. Kind of will be my belated xmas presents :santa:
Edited by Ants
Quick update.
I ported the other manifolds today in this ridiculous hot and stormy weather (but made it up by having a few beers after ;) )
All marked and ready for porting
Photo of ported manifold, but I am not happy with it :angry: and will need to do some more....but I promise I will not upload any other photos of them :yes:
Now cosmetically speaking I received this
I always get exicited when I get things delivered :banana:
More excitement....
Tadaaaa!!!
Brand new N1 headlights that will go very well with the rest of the car :)
Edited by Ants
  • Like 1
N1 lights will look good in your car, i love them they made huge difference in overall look of mine
How much did you get the Dremel for? Looking at buying one of these at moment as well for pretty much same reason you bought it for :thumbsup:
Humm....if my memory serves me right the Dremel kit cost $149 from Bunnings for the model I acquired (also inc. 36 piece set). It is an awesome tool and although not that cheap you can do magnificent work with it.
Edited by Ants
Rightyo,
My front bumper needed to be repainted due to the stone chips, scratches and scuffs it had endured while being my daily for several years, so me being the nutty professor that I am :woot: I decided to do it myself (you guys are probably gonna laugh your ass off)
So for this recipe I went to Autobarn and got
$50 worth of paint stripper,
Some White Knight Rust Guard all purpose primer (white in color) from Bunnings costs approx. $15 per can (I purchased 4 cans but only used 1 & 1/2 cans)
4 cans of Holts auto spray (paint code PSH01) which costs $25 each from Autobarn (but only used 2 & 1/2 cans)
The official paint color code for you pilgrims ;)
and finally some Motospray Top Coat Clear Coat (the can on the left) also from Autobarn (cost approx $12 per can purchased 3 cans only used 1 can)
Now for the exciting part...the front bumper preparation
Semi stripped and while I was at it put some holes in it to fit some N1 vents (I had photos of measurements and fitting but just I somehow wiped my Iphone clean and had to source backup photos but unfortunately this one gone god damn technology :angry: )
Photo of semi stirpped front bumper with FRP N1 vents fitted (they will not be remaining in there...and I will touch on that a bit later)
Photo of bumper now fully stripped of paint, sanded with 1200 grit and cleaned ready for primer
The white bits in the centre are holes filled in where the number plate use to reside :blink:
All primed up
Just another shot
Front shot of primed bumper (excuse the quality as it was dusk)
Wrapped up and protected to be resprayed another day
The other day is here....first coat of spray (and yest it was resprayed in the Garage)
Another coat completed
I was quiet amazed of the quality of the spray paint that came from a can!
It is all comming together now
Photo of final coat
Outside drying in the beautiful warm (fooking hot) sun
I did not want to put the FRP N1 vents in I sourced some brand new N1 vents from RHD Japan
Photo of finished resprayed bumper with genuine N1 vents (BTW I have not painted the N1 vents as they came white)
Just another shot of it
Outside shot of resprayed front bar
and another shot (the N1 vents fitted perfectly and no adhesive required as it has side clips)
A final shot.
I know its not as good as 2pac paint but I thought I would carryout this expirement to see its results as respraying it can be rather expensive (I was quoted $770) and I like to do the work myself :geek:
Next will be the lower lip.
Edited by Ants
Received some brand new nissan OEM parts from RHD Japan the other day
Turbo gasket kit, turbo exhaust studs + nuts, manifold studs and front grill clips as mine are fubar'd :cool:
New relay box cover
This will replace my weathered relay box cover and makes the engine look.....well look a bit newer :whistling:
Brand new hood sealing rubber (the bit that goes onto the front apron)
In addition to the above I also got the following
New Bosch fuel filter (I actually purchased two and I dont know why as the car only supports one filter :blink: )
X 6 New NGK iridium spark plugs
New polyurethane exhaust mount bushes to replace the old sh#tty ones purchased really cheaply from ebay
Brand new turbo oil return piping for the GT2860R-5 also acquired from ebay
and finally Kando Dynamic braided oil and water kit for the GT2860R-5 but I probably wont fit them as the OEM are probably more reliable IMO.
More parts to come soon such as Nismo intake plenum, Tomei expreme TI exhaust, and others but will keep them as a surprise.
Edited by Ants
Yeah RHD is great and I have used them many times before. I am going to try perfect run japan for the Nismo intake plenum and see what that is like as they seem to be quiet good price wise.
Today I decided to port the -5s as per my previous posts there was quiet a difference between ported ex. manifolds and the -5s ex. housings.
So first up
we need a GT2860R-5 turbine housing like above (notice the rusty bits we will get that removed as well)
Then we get the turbine exhaust housing gasket
and place it on the turbine exhaust housing like this and then
get your trusty permanent marker and mark around the outlet
and get something like this
then it is time to take the turbine ex. housing off the turbo and you are going to need a spanner...I prefer the ratchet spanners like the one above and are very useful to get to hard to reach places in the tight RB26 engine bay :huh:
So lets go to town with the spanner like so
Remember to take the clip off the wastgate in order to remove the turbine ex. housing properly :yes: I just used a flat head screw driver
After you have removed the necessary bolts and wasteate clip you shoud end up with this
Put the bolts and clip in safe place where you can't loose them as that is the last thing you want. I put them in zip bag and then placed them in the turbo box.
Turbine ex. housing before
Turbine ex. housing after being fresly ported
Turbine ex. housing after being sanded with dremel tool and then sanded by hand with 1200 grit wet and dry sand paper (also sanded the rusty bits on the exhaust plate)
Next is to put the turbine ex. housing back on the turbo.
Here is a photo with ported ex. housing next to the standard turbo ex. housing
here is a better photo showing the difference in size between the ported turbine ex. housing and the standard one
That is how smooth the ported ex. housing is
Ported the second turbo and looks like this....ooohhh very smooth indeed :D
Photo of both turbines ex. housings ported
Finally, the turbos are wrapped back where next time they see daylight will be for installation on the new Tomei Advance Spec RB26 ;)
Now whether there are any gains realised from the porting I cant say for sure, but what I can say is that the turbos should have come like above to start of with IMHO. Will it effect boost, mid-range I don't think so.
I guess once new engine is run in and tuned we will then see the results.
Edited by Ants
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
