Hey Ants! I just read through your build thread... i was bored at work today :)
Loving your attention to detail, I wish i had the time (and $$) to put as much into my GTR. Maybe when I retire mine as my daily.
I'm glad you've soldiered on looking forward to seeing the end result of all your work!
thanks mate its always appreciated to hear that (things you do when your bored :teehee: )
its a bit of a roller-coaster ride FTM and I am trying to deal with it the best I possibly can.
Really enjoyable build bud, Will be checking for more updates!
Thanks buddy. I endeavour to have some nice updates coming very soon :yes:
Edited by Ants
few pics while I was at workshop
Garrett -5s bolted into place with HKS actuators set to 15psi each (my beautiful daughter in the backgrounds :) )
Mines dumps pipe - sexy bit of gear
braided turbo oil and water lines fitted
here you can see the new silicon hoses fitted (pushed aside FTM)
Will have some more exciting updates coming very soon, so watch this space ;)
Awesome build mate loving the little 1%'s like match porting etc. it makes a lot of difference in the end when you've put so much of your own hand time in. Even tho it may not be quite as good as what a pro shop might have done, if you can do a good job yourself I think that's always better. I bought a tig welder and did my own fab work. Didn't really save myself much but it didn't leave the garage and had some fun at the same time. Any muggins can pay someone else. Not so sure about spray can painting lol I'm a ex panel beater and was lucky enough to do my time with a prestige shop, so not so big on spray can jobs lol. But credit to you the bits you've done look quite good. It's coming together great, going to be a very very nice car that engine is a ticket item to making it a stand out. Special Japan magic. Putty I'm a thousand or so Kay's away otherwise I could of sorted that few little rusty patches for you. I'd say she's seen a little bit of salt in the northern parts of Japan. Not as bad as a lot of them tho. I wouldn't be too worried about what you uncovered, minor. Keep it up mate.
Edited by Mr. Untouchable
Thanks for the positive comments mate. Yeah, although they may not make a massive difference performance wise, all the small things make a big difference to me. Seeing the results from doing the work myself is satisfying and considering I work in an office 5 days a week and that any mechanical or detailing work is not my profession makes it even more satisfying. What I also like about doing things on my own is that I get to learn (from mistakes as well :whistling: ) and I'm quiet nicky picky with things so can only blame myself for not doing it correctly ;)
The rust is an issue and even after I have the engine installed and I have more work to do on it and will keep this build / restoration thread alive for a bit longer.
awesome build mate, really looks the goods. that tomei crate motor is the goods too, cant wait to see this thing in the track. good luck with it, and stick to your guns, it will all be worth it at the end ;)
Thanks Dale. The Tomei engine is really my dream coming true and even I cant wait to see how it goes. Will certainly be sticking to my guns but I am also happy to listen to others which is what makes this forum so special :yes:
I have decided to go another way with the ECU and received this today.
Haltech Platinum Pro Plug In ECU - hopefully it can back up its great reputation. If not I still have a Apexi PFC that I know will deliver results.
are you going to ceramic coat the dump pipes?
No that would be a crime :P . Besides, now they are bolted up I'm not gonna bother, although I know it would assist keep heat in the exhaust rather than the engine bay.
Good choice on the Haltech, I too am thinking of going down this path.
Do you plan on retaining the AFMs? The thing that put me off the Link is that apparently it will not allow me to run the AFMs.
Yeah. I had been talking to a few guys on SAU (namely Qld members ;) ) and really educated me on ECU choices. One of the key reasons why I've gone Hatlech is to do away the A/F meters.
The other reason is that it has more tuning capabilities than an Apexi Power FC which is good to have for track days.
Awesome build thread man, Can't wait to see the
final result.
All the best.
thanks mate.
Oh, so that's the one you bought. I thought it was new.
Great deal that one!
yes, that's the one ;)
  • 3 weeks later...
Apologies for the delay everyone.
Engine is now finally bolted into the car :)
Just need to attach a few more ancillaries including exhaust, fluids, then run-in tune. then after that she will be back with me :banana:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
