stock-photo-choosing-now-written-on-blac
It's been on the dyno. GIVE IT SOME! :D
RESULTS!!!!!!!!!!!!!!!!!!!!!!!!!!!
Where you gonna peg the boost needle Ant eater?
lol........soon Paulie very soon.
Have no idea what Sean is setting things at so I guess everything will be revealed when I get to pick up the ant-eater
Ok, thats fair enough Scottie.
Many apologies to all regarding the slow progress of late regarding this project.
I have been trying very, very, very, hard to get things wrapped up but alas these delays are unfortunately out of my control (which has been frustrating the hell out of me :verymad: )
So, after I called the tuner last week (who was frantically focusing on getting ready for Jamboree), my Haltech ECU decided to more or less crap itself after an hour on the dyno - something to do with the coms port not reading. The tuner told me he has sent the ECU to Haltech for repair.
Needless to say that after that conversation I felt pretty much guttered.
From seeing the Ant-Eater being tuned on the dyno to this was rather depressing. Although its a new computer (as in never been used) its out of its warranty period.
Anyways, to cut a long story short, I have been in contact with Haltech today (who are a great to deal with BTW) to find out what the prognosis is.
The ECU has passed preliminary testing which is positive to hear. However, there is a display error - im not sure what this means yet.
I have been told that the ECU will be returned tomorrow to the workshop, so hopefully it will be all good.
That is all I have for the moment guys.
I do hope to have some communication from my tuner this week and x fingers it will be ready soon.
Once more information is made available to me I will off course update you's all.
Oh man! Your so close! Not long to go now :)
Glad to hear Haltech were happy enough to assist you though, i was strongly considering one before i picked up my nistune. However local Adelaide support was the decider for me.
Get us some dyno footage :D! Must hear... rb..
Sounds frustrating to say the least, mate. Bear with it, you've come a long way with the beast and have had bigger hurdles than this! You're close, and I look forward to seeing the final power run video with power graph :)
Ok,ok..............so the Ant-Eater Finally got tuned :)
I will just post up some pics so they can do the talking.
Enjoy ;)
All results using BP Ultimate 98
Thread needs more pics of the car back in your hot little hands Ants.
Not sure where about you live but have you thought about trying it on E85? or maybe getting the Haltech Flex Sensor and run both. Sorry if this has been covered before
ah the ever dangerous "........for now"
can I just say power figure aside that torque curve is AWESOME!!!......
smooth drive and given the motor reliable as....
Im guessing that 350 on a "Run in " tune ?????
I'm thinking in 6 months this shit will get re-dic
ok here are some photos of the Ant-Eater I quickly took today
So future plans are to get it tuned on E85 and install an ethanol sensor just 4 piece of mind and hopefully crack that 400rwkw.
Since I have a United service station literally not even 300 meters away, the availability of E85 is not an issue.
After speaking to Sean, he mentioned there is plenty of power to be had. So things look promising.
  • Like 2
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
