So.. I may just be a "little" bored at work :P
I managed to read this whole thread during yesterday and today!
Great build mate! I've loved every post and I can tell no expense has been spared in the duration of this build.
Though I did get real bummed out after reading on from your shell issues :( I hope all works itself out and I'm sure no matter what you decide it will come up mint ?
Keep them up date's coming mate!
Edited by MC-WOSHY
  • Like 1
Though I did get real bummed out after reading on from your shell issues :( I hope all works itself out and I'm sure no matter what you decide it will come up mint [emoji108]
Thanks mate appreciate the comments
well the shell issue means there will be another chapter to all of this it will just take some time
  • 5 weeks later...
So after after 13 years its time to say farewell.......
After reflecting rather deeply of late, I am going to part with the car and an add will be posted in the coming weeks.
I have had loads of fun but also have had my fair share of downs with it but that comes with the GTR package.
I am at a stage in life where I have larger priorities now (my family being the main one) and I hardly get to drive it and now have even less time to work with it.
Plus from a commercial perceptive its at its best right now. Not even 5,000km on that motor.
Please note that I will be one picky mother f**ker when it comes to selling it as I want it to go to a good home that will give it the love and attention and respect it deserves.
But it certainly wont be my last GTR as its in my blood.
GTR for life.
GTR for life.
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
