I've been told that all cars, in particular Japanese cars, overestimate your speed, so that the speed shown on your speedometer is actually off by a bit. I tested mine using a phone app called Ulysses Speedometer which uses GPS tracking to measure your speed exactly. I discovered that my speedometer is off by a ridiculously huge 8.3%. Which means when my speedo reads 100, I am actually only driving 91.7. And that to reach 110kmph which is the top speed on some highways, my speedo actually has to read 120kmph. I dislike having to estimate the speed I am driving at and never quite sure if I am now speeding or not, and am annoyed that I must be the frustrating person on the road driving unecessarily under the limit.
Have you guys measured the difference on your car? Is it similar to mine? Can it be adjusted?
Edited by puddlejumper
my old car had speed on the turbo timer which was usually about 2 kph less than the speedo at about 100km. the timer was calibrated at 60kph from the speedo though...
Comparing speedo to satnav in other cars usually had about 2-3k difference also (but they weren't jap)
So i think usually a speedo is only a cpl k over actual speed.. things such as tire size and wear can have an affect on the precise accuracy...
As per above, unless you are running the stock tyre sizes (which almost no-one ever does - even on stockies), then you will affect your speedo's accuracy. My tyre width/profile is WAY off - my speedo is out by about 15%, but I compensate for it and normally use my GPS digital speedo instead of the oem cluster.
You will find all the V35's and M35 Stageas have this discrepancy, but the ecu gets a good speed signal and you can display this actual speed via the obd2 port. (it is much more accurate.)
I agree, it is very annoying and can cause frustration, 10k's out at 100 is a joke.
My V35 is fairly close. About 2% last time I checked with GPS. And I am running stock size tyres.
But our J31 maxima is out by about 8%. Again with stock size tyres.
My V35 Coupe seems to almost spot on - I've tested at 80 & 110 against the GPS in my phone, and the difference is no more than 1 - 2 kph. I've got 18s with stock rear tyres - 245/45R18.
I got 2km/h difference between the fronts and rears because of the tire sizes (width and profile) that came with the wheels, I'm not sure how much it is in relation to the speedometer. Use this tire size calculator (http://www.1010tires...ecalculator.asp) to help you choose the tires within the closest possible tolerances for your set of wheels. There may be other factors as well...
Edited by 81gSKy
Here's the results of a test I did a while ago. As per above, the Informeter (display from OBD2 data) is accurate, thus confirming Nissan deliberately engineered our cars to show the incorrect speed on the dash.
So, are we saying that the GPS is connected to the engine control (ie fuel)? and the traction control as well? What happens when the GPS loses a signal?
?? GPS is only used for Navi. If you don't have Navi, your car doesn't even have a GPS receiver. the ECU uses wheel speed sensors to determine vehicle speed (as well as using them for ABS, TC and VDC). If you are running stock size tyres, the ECU speed derived from these sensors is quite accurite.. however, the speedo doesn't display exactly what the ECU reads, the speedo almost always reads faster.
If you look at the graph above you will see it isn't 10% across the board.
I corrected the speedo on my J30 years ago, there was an adjustment on the back of the speedo cluster which adjusted a % of speed, however, the speedo was also out by an absolute figure, there was no adjustment for this, but fortunatly I was able to elongate the mounting holes where the speedo mechanism attached to the face, that allowed me to make an absolute adjustment and I was able to get the speedo to read accurite at 60, 80 and 100km/h.
I had a look at the back of the speedo cluster on the J31 Maxima, but there is no physical adjustment.
at least puddles speedo is out in the negative direction. years ago i found out the hard way that my car was showing 100 on the speedo but was actually doing 111 on the road... *flash*
You should've been able to contest that... Right?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
