  • Replies 45
If the car is a write off any idea what I would get as a payout? Also how do i get the option to buy it back?
Has anyone had any experience with micolor or DT panels?
Yeh I'm calling write off, you would have to get a few valuations done on it minus damage, there's a few other ways but I don't know if u can do that now, probably will have to speak to their insurance and work something out with red book or glasses guide values
You would get paid out whatever the market value is on the insurance.
But given it's not registered and not in a RWC state (perhaps), that might be a tad lower.
It's not looking good.
Does anyone know when DT panels opens again? Or micolor?
Mick (Micolour) isn't back I think till the 2nd week of Jan, probably the same for other places too
fair stack :D
for reference when my 33 was written off it was insured for market value so around 11,000
i had the option to buy the car back at time it was declared write off and they would let me keep the car and pay me the difference, around 6k ish and its no longer available for comprehensive insurance or let them have the car they pay me out the 11k minus excees etc
That's what I said, you said if the car was parked illegally it would be the stationary vehicles fault, or implied that way at least. So yeh, it is a broad overview
Parked illegally like if you park in front of a fire hydrant and then there's a fire they will damage your car to get access and you won't be covered
Lol, does anyone else want to repeat what I said? Anyone?
DT reopen Jan 2.
My 33 was written off in March this year, got pad 12700 from memory (after excess). Had option to buy it back but didn't look into it.
Edited by gtsttrk
Ouch, that thing's a write off for sure.
You should be covered by their insurance, regardless of rego or not.
Were you moving at the time? Or was it parked outside your house? Either way, you might be in for a visit from Johnny Lawman, but if it was just parked you might get lucky.
That's a bugger mate, if it's not written off I can vouch for Mick at Micolour, he's not the cheapest and will take his time (which is good) but he's worth it.
Also, if it's parked illegally... wait, what?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
