  • Replies 347
Haha considering the fact that a rb20e only has around 100kw, thats a 0-100 time of 10 seconds ish. (from calculation of the 147kw rb25de 0-100 8 seconds).
I'd love to see a rb20e try to do a 10 sec 100. Some poor bugger has one in aust. They should do a test.
There's a bunch of em kicking about, pre sevs imports. A few in HR31s as well.
In response to OP:
Are we counting Rotary N/A?
They're pretty quick but that's more about having a lightweight body than having bucketloads of power.
Hate to burst this bubble of worship guys, but NA rotories, still slow.
Even the panspeed car only had like 500HP
Worked 20B.
Dill with it.
Worked 20B.
Dill with it.
*Cough* Not slow when bolted into an 800kg r100... *cough*
Yeah, but that's the point, you HAVE to bolt it into something that is sub 1000kg to make it go hard.
Don't get me wrong, I do appreciate my normally aspirated rotangs.
Just sayin'
Just sayin'
Same theory as cortinas, average motor bolted into something light = fastish
NA skylines are the same as a decaf skim latte.
Why bother.
Because then u get to hang out with the cool kids in the coffee shop, same principle.
Yes a commo will smash ur Natro skyline, but with the skyline silvia 300zx soarer whatever it may be they're Natro versions are still "welcomed" to events such as down shift meet ups, club cruises and jamboree.
It's a conformist/wanting to belong to something thing
Hey hey hey, I've just got wiring left now ;)
ive just got the exhaust left.
whats your point?
I will laugh when my rotang starts before both of your cars ;)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
