Scandy - glamped refers to glamourous camping, which is the best description for tenting in a caravan park (ie toilet & shower facilities).
Imo that's not camping, but rather glamping. It's only camping when you've got to dig a hole for 'sitting' on.
Now.... Swisse advert on tv with Ponting batting in the nets. What's the song?
You mean that Ad?
I'm well aware of the concept of 'glamping'. I just find the word to be utterly ridiculous.
the missus put me onto it, lol.
hadnt heard of it until last week ;) makes sense tho.
Its good you clarified that, cause I'm sure a bunch of folks thought it meant Gary Glitter in a tent.
Kids can now camp in caravan parks, assured of their safety...
-D
If anyone cares Fast and frivolous 6 comes out may 24 and they wreck new mustangs, ferrari , chevy muscle
The silver r35 is back too
Filmed in UK and Germany
All the old cast and "the rock " is still chasing Dom
Plenty of new spicy hot chicks as well
Trailers out on youtube
Also announced F&F 7 !!
Be fun to cruise to drive in when the time comes ?
Even if you think its cheesy ,it still fun / worth watching instead of another Romcom
Edited by Carbon 34
wheres the 'real' trailer? all i see is 8 month old fake trailers haha
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
