need a lil help guys, was driving the gtr just cruising at 60 changed gears nice n slow n I felt a funny twitch in the clutch pedal and then next time I pushed the clutch is was a lot heavier all of sudden.
pulled over check the fluid levels all looks ok, then I noticed when I got back in it every time I pushed the clutch it was making a noise like gas escaping. This was in the car not under the bonnet.
so I hear this is possibly a vacuum leak in the booster? anyone got any other ideas?
anyways I drove it home and it felt fine aside from the weird noise and being heavier clutch than normal, went into gear fine no crunch.
What im wondering is, is this doing any damage to the clutch? I have the nismo coppermix twinplate so I don’t wanna stuff it up but its normally light as a feather and id actually prefer a heavier clutch pedal.
o and this car is starting to p me off
Edited by Inline 6
Sounds like a throw out bearing... Or more likely a split in the clutch vacuum booster pot steel casing...
Check and see if the noise is coming from the clutch pedal pivot area.. With the pedal getting heavy though I would say that it is the booster...
I hope it is nothing worse than that...
It's gotta be the booster Dan. If it was anything else it would be crunching/notching gears. I wouldn't expect it to be doing any damage to the clutch.
Edited by dark.sky
Get the standard one welded up strong, nismo one is standard with som tack welds to reinforce......
Yeah my mechanic took it out and seem welded it and put a strengthening plate as well... much cheaper than going aftermarket lol
G'day, looking for a little help/advice..
I've been out of the loop when it comes to parts prices and just wanted to know what you guys think. I'm looking to buy a r33 rip the motor and box and replace it with my built stuff. Question is; what are r33 s2 motors + boxes worth now days. Am I dreaming thinking I could get $3000 for both including loom and clutch? Are they still moving fairly quickly or are people not buying them? When I bought mine 4+ years ago, I paid $3500.. I want to know this before I buy the 33 so i know weather or not its a viable option..
Cheers!
Yeah as mentioned above ^^^ best bet is to call a couple of wreckers or import specialists wreckers a call and find out how much all that kit is worth these days. It will give you at least a ball park figure to work with.
Was driving today and this happened, its the left side bracket on a R33 GTR drivers seat. You might also notice it has been welded in 3 places by the previous owner haha. Anyone else had this happen to them?
Also I swapped the passenger side bracket over to this so i can get around, anyone know if a gts seat will have the same bracket?
someone buy my old GTR and give it a good home;
http://www.gumtree.com.au/s-ad/ridgehaven/cars-vans-utes/nissan-skyline-r32-gt-r/1014576914
runs 10's:)
.. it's a shame YOU never ran a 10 in it :D :D :D
Cheers!
Pretty sure you are dreaming - RB26s can be had for that sort of money (I sold one on behalf of my brother-in-law for well under $3k 2 years ago). Generally RB25s hover around the $1,500-$2k mark - maybe a bit more incl. the loom, and if the clutch is decent. But you never know - selling 2nd hand parts is a funny business - sometimes you can barely give things away, and other times you could have sold a thing 10 times over for mor cash then you got.
Yeh I was saying 3k with complete motor (inc. loom, clutch, everything) AND box. I think $1800 for engine and $1200 for box is fairly reasonable.
I know what you mean, I've sold plenty of parts and its just a matter of who wants what at the time. I remember when buying my 25, everyone wanted one. I got mine at $1900 and that was a steal!
oh snap!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
