Food - What Is Good, What Is Ok, And What Is Really Bad For Us
I'm getting a DEXA scan next Tuesday, should be tops. Did you get one done Birds?
Not yet, but I'm keen to. Might book in this week. It'll be purely for interest's sake; I can't see my BF changing much anytime soon to make follow up scans worthwhile. Be good to take a pic and say this is me a x%.
Edit: have increased food intake and lifts recently, so might be worth it afterall.
Car runs great, I'm just over it. It's pushing me dangerously close to depression lol
Get a motorbike - depression alleviated.
Not yet, but I'm keen to. Might book in this week. It'll be purely for interest's sake; I can't see my BF changing much anytime soon to make follow up scans worthwhile. Be good to take a pic at 37 degrees angle from the passenger side window of an R33 gtst with 10% window tint at exactly 4:37pm on a day which is 29 degrees with 59% humidity and say this is me a x%.
Fixed?
That's the plan (though a dirt bike, at least while I'm restricted on my Ls) however I can do that until I f**k this car off. I'm either going to strip it for parts and get roughly $11k give or take for everything, or sell the shell as it is now for $10k neg, registered, and legally engineered.
Eat a jar of Natural Peanut butter and do squats.
Depression and car care factor cured!
I essentially am blaming part of my bad mood and HORRIFIC FEELING in my gut on organic peanut butter lol...ate like 6 rye biscuits with peanut butter last night. The last time I did that I also felt this way (last Friday). Correlation may not equal cause, but f**k it that'll do for now.
What's the difference between natural and organic?! o.O The stuff I get is the Woolworths Macro wholefoods shit, since that's the only peanut butter I've found that lists "100% peanuts" in the ingredients.
...>.> I just posted that URL... And was asking time not website. No matter! Compare notes next week!
You totally posted dexascan.com.au instead of bodyscan.com.au
Unforgivable
Troy
YES
NO
Natural peanut butter is in the "health food" section of woolies - where the protein bars and powders are.
the stuff you have is from the same section where the regular peanut butter is but in it's own "MACRO" branded section.
Try the Natural one.
Please explain your reasoning, other than cost. The sanitarium shit still has added salt and/or sugar. The macro stuff does not, and is only peanuts.
I cannot fathom why you suggest something with additives over something without.
Look at the label and see which one has less carbs and salt?
Still shouldn't be applicable, even if the macro one has more calories/carbs/whatever....it can't have more salt considering it has NONE added.
The only way the macro one could have more calories/carbs/whatever is if the Sanitarium one is being watered down....so my question remains, why the hell is it better than something that's purer?
TOLGA YOU BEST BE TROLLING ME BRO
I think TTT statement covers a wider area.
Organic foods aren't always natural.
orangic is just the way it's grown, sugars etc. can be added and it still be an organic product.
The natural ones have no additives
and doesn't organic shit cost way more?
Edited by jangles
OK now that I go to Sanitarium's website and look at their "natural" peanut butter, I see that it's also 100% peanuts with no added salt or sugar....I was confused given that they have a different product that is CLEARLY LABELLED "No added sugar or salt", leading me to believe that since what he linked wasn't clearly labelled as such also, it must have them added.
Now the only argument would be price, which I dare say Sanitarium is probably cheaper.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
