We have been using a Motorsport systems strain gauge. I flat shift 3rd to 4th and clutch other gears, not sure how dean our driver does it, I'm still learning so I was advised to only flat change 3rd to 4th. I messgaed Ex bsm to find out what happened few days ago but no response as yet.
This was the recommended and only way ;) now Incorporate the ikeya shifter somehow!!! :P
Shared a garage with the sigworth car last year at wtac.. certainly not your regular backyard crew.. Was very well oiled and everyone seemed to have a place,... Times improved every session but testing was lacking from what I could see... Didn't realise how quick the QR times were... Pro Am seems to be the right class! (Phew) :)
Probably be free for those guys
Looks awesome the car list so far
Throw a time attack car in for a laugh
Set of AD08s coming next week for some random testing in the weeks to come
Did you pick up the tires locally with the wtac deal?
Where u testing? Should tee something up when I'm ready !
Nah no info on the deal but I shopped around and found a place which had stock, and only set me back $375 a tyre!! So well under the price Yokohama have on their website
Probably go Wakefield for a day then get out to EC when the tuner has his Evo ready and his pro driver gives me tips hahaha
If anyone is interested there is a set of 265/35/18 AD08s for sale brand new for $1500
Same guy i went to get mine today
If you are interested give Tyres & More Wetherill Park a call
He has one set left and there is not alot of stock in sydney nearly 0!!
For a reference point as I'm not familiar with the track, what kind of lap times would the pro class drivers of last year do, ie mark berry gtr 34, or even his 32 and other drivers?
I noticed the byp integra is up there's with em, is the circuit more like Winton? As in better suited to light weight cars that handle than overall power if you get what I mean.
That front diff and transfer case Richo put in is doing the job :)
ah noooooooew.
We ran out of fuel!!! Ended up with a 1.04.9. Had a low 1.04 in it, but wasn't to be.
Huge challenge even to make the event. The old man and my brother put in a big effort.
In the weekends leading up to it we dropped a heap of weight, did heaps of maintenance to suspension bits, changed the diff (mine is broken, no time to fix), borrowing brake pads on Monday night (i was working in sydney tues-fri) and in the days before get a wheel alignment and new tyres (on Friday).
At a track I'd been too once before, with tyres I'd never run before (z222 285/35), with no ABS (borrowed diff was a non ABS unit) we ended up 4th in Club, so very close to 3rd.
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
