  • Replies 50
2012 SAU-Vic EGM/Committee Elections
Time: 6:30-10:30PM (7:30PM Formalities)
Date: Wednesday 20th Feb
Food: Finger Food.
Drink: Beer & Soft Drink
The 2013 SAU Vic elections will be held via EGM at the February Club Meeting on Saturday 16th February 2013
At this meeting, the new Committee for 2013 will be elected. All current Committee members will step down on 16/02/2013.
So when exactly is / was this?
And isn't it the AGM (Annual General Meeting)? An EGM is an Extraordinary General Meeting.
An AGM is exactly that an Annual General Meeting
And EGM is an Extraordinary meeting, a meeting called upon by the Committee members
Not sure what the relevance of whether its an AGM/EGM has any bearing on the topic discussed at hand
"The Annual General meeting (AGM) is an important event for every organisation. It gives its members, the general public and the committee a broad overview of the organisation's current directions and financial health and confirms its purpose.
It is also the time to revitalise the organisation through the official engagement of members into key elected positions."
An Extraordinary General Meeting is called at times other than an AGM, usually in response to a crisis occurring in the running of the organisation.
Feb 20 is surely the AGM, as dictated by the rules of incorporation.
Are we really going to argue becuase the post has an E and not an A? Are you not going to turn up because its an EGM and not called an AGM?
The agenda of the meeting is clearly outlined in the first post.
The rules of the Club are governed by the Club constitution, this dictates how the club is run. There are no set rules from every incorporation. i could call it a PGM (Party General Meeting) and if that's what the constitution says that's what it will be.
In addition we have already had a AGM this year. So should we call this our Double Annual General Meeting?
If you have any further issues of what we call our meetings please contact Consumer Affairs on 1300 558 181.
Or feel free to nominate yourself as Treasurer and re-write our club constitution.
Sorry Tony, but you are wrong. The club may be governed by its constitution, but that constitution is governed by the Incorporations Act, which has recently been amended. As an executive committee member, this is something you need to be aware of. The Incorporations Act contains what are termed "model rules", and it is these that are generally used to form the constitution of incorporated bodies, like SAU-Vic.
If you have already had an AGM, then that is the time you should have elected a new committee.
Because the Incorporations Act 2012 has changed the "model rules", many incorporated bodies are calling Extraordinary General meetings to pass a resolution to the effect that their constitution be changed in line with the revised model rules.
As an executive member of the committee, I suggest you familiarise yourself with the rules that govern the operation of incorporated bodies.
The club's constitution doesn't need re-writing, it just needs to be adhered to. Unfortunately, I can't stand for committee, as I am not a financial member of SAU-Vic.
(FWIW, I have some 20 years experience in serving on the committees of various incorporated bodies)
It's governed by the 'model rules' or it can create its 'own' rules.
Model rules versus own rules
Your association may use the model rules, or create its own rules. Either way, the rules must address every item listed in Schedule 1 of the Associations Incorporation Reform Act 2012
If you want to further discuss this please take it to PM and not to clutter this thread.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
