hi, I have got some r32, r33 engine parts for sale. also some rb30.
rb20det crossover pipe x 3
rb25det crossover pipe x 2
rb30 crossover pipe x 2
rb20det stock bov x3
rb25det stock bov x 2
rb25det air compressor bracket has been soda blasted
rb25det hicas p/steer pump
rb25det non hicas p/steer pump
rb30e na camshaft gc
rb30 na starter motor x2 (auto and manual are the same)
rb20det starter motor
rb30 stock cam gear
rb25det sII stock cam gears
rb25det p/steer reserviour
rb25det polution canister
rb25det cas bracket
rb20det stock dump pipe x 2
rb25det stock dump pipe x 1
rb25det oil pump
rb25det oil filter cooler sandwich plate x2
rb20/25det stock exhaust manifold x2
rb20/25det exhaust manifold heat shield
holden rb30 rocker covers
tridon rb30 thermostat. used for maybe a week max
rb25det neo cam covers
internal fuel pump r32/r33? jecs
rb20/25det thermostat housing/lower hose to block pipe x 3
rb alternator slider bracket x2
rb30na heat shield
factory vl turbo A8 pistons and rods x6
rb30na exhaust manifold down to cat
p/steer pump brackets
neo engine cover bracket
rb25det neo rocker covers
rb25det bare intake manifold $15
rb30 sump
r33 rb25det cooler hoses
stock sII rb25det injectors
Stock sII rb25det coilpacks
Call Jamie. 0433 559 722. pick up from rothwell, brisbane northside 4022
Edited by gold-3lt
https://www.sau.com.au/forums/topic/418685-skyline-parts-rb20detrb25detrb30/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
