With SAU VIC Winton track day just around the corner I had the realisation that I needed to get the standard bootlid/spoiler setup back on stat.
Didn't have any time left so spent a couple of nights with $120 worth of paint supplies. Didn't expected a pro result but it'll get me by for the 2015 season at least.
Didn't turn out as bad as I thought it would be. (although I wish I had an effective way of baking the panels afterwards).
Orange peel galore atm. Will wait a couple of months for it to all harden properly before giving it a good polish.
Rear badge removed off the old fibreglass bootlid, cleaned up and 3M double sided tape applied.
Spent ages measuring and getting the badge on exactly in the right spot to the mm. (11mm from the bottom, 30mm from the right) - SAU to the rescue once again with that info. Lots of sweat involved in this task.
The photo of an 32GTR with factory bits isn't amazing to anyone but me....
For the first time in 10years since I've had the car. Rear spoiler! Spent quite a while looking at it, last night. <Sob>
Soooooo changes the look of the car.
The fibreglass boot lid that the car came with from Japan. Impressive quality and very light. Will be hanging onto this.
Next stop. Boot lip. The one I have has a few holes that need to be fibreglass, patched up so that will have to wait.
  • Like 2
  • 3 weeks later...
Some odd and ends from RHDJapan for some upcoming small projects.
Brake Line A Clamps, Sideskirt clips & Nice shiny new replacement door handles.
On a separate note, I finally measure the offset of the 17"s that came with the car.
+0 Offset TE37's. Figures why they filled out the guards so well for a 9" rim.
Hey, can you tell me what the part number is for the door handles please?
Cheers
  • 3 months later...
This shiz needs updates.
It does. I've lost momentum recently and this is why.
Leaving in the morning, earlier in the year in March. Winton Circuit Club Track day.
This is how the car left the March Circuit Club Winton track day. The motor didn't fare too well unfortunately.
Thanks to team gtr_jet for getting the car home. Would have been majorly screwed otherwise.
Sat on it for a couple of months then finally got it sent to Racepace.
Ahh the natural home of a raced GTR - on the back of a tow truck.
Racepace were nice enough to pay for tow back. Sitting back at home now in it's current state.
Least I get to paint the engine bay now, I guess.
I'll post up later on when I get time what we know so far. Guesses on what went wrong?
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
