Happy Friday!
Just got this picture back from Craved Coatings of the finished product.
Cost around $308 including courier back to me. Should last for another 3 rebuilds at least ;)
Hopefully they arrive Mon/Tue. Gotta book the car in at Racepace now, which will make it a bit more than a year since the last motor died.
  • Like 4
Covers arrived back from Craved Coatings yesterday.
The below photo still doesn't do them justice. They're a deep metallic candy red. Pretty close to how I originally painted them.
Will take a better photo of them in better light once they're on the car.
  • Like 2
  • 6 months later...
Aaaaaand WE'RE BACK!
Admittedly, got the car back around a month ago but haven't had time to post anything about it.
Been pretty busy with the new home.........for the GTR. House with rear, drive through access and a nice big garage that will get some work done on it in the new year.
On a run-in tune @315rwkw 18psi. Gotta find time to get it between 5-800kms so I can take it back for a retune back to 335rwkw @20psi.
  • Like 5
Thoroughly enjoyed reading through all 25 pages, gave me some motivation for mine when it comes back from an engine rebuild.  Time to get saving.
Car looks awesome!
  • Like 1
It makes me happy you have this back....updates!
Update?
Just a bit dusty and unloved ATM. Haven't even done enough KM's for run-in of the new motor build yet. Gotta set some time targets, I think.
I know that a couple of people have said this, but I just read the whole thread start to finish in about 30 minutes glued to my screen! The way you have done your interior has seriously inspired me to buy lots of goodies off RHDJapan [emoji23] Recently got into my first GTR and this is my first post on the forums ?
  • Like 1
11 hours ago, Bennjamiin said:
I know that a couple of people have said this, but I just read the whole thread start to finish in about 30 minutes glued to my screen! The way you have done your interior has seriously inspired me to buy lots of goodies off RHDJapan emoji23.png Recently got into my first GTR and this is my first post on the forums ?
Welcome and congrats on the new R. The interior is a nice way to start off on one of these cars, if you just got yours. They look a bit bland these days and little bits and pieces really lift the overall look.
39 minutes ago, Anfanee said:
So how about those time targets? :banana:
Yeah I hear you. First service on the new motor will be in Jan so maybe a bit quiet till then unless I get motivated.
  • Like 1
  • 3 months later...
Updates!
First service on new motor and re-tune done. Back to where it was and it feels good.
16387163_10154458728317734_3744676137276
Recruited & trained new staff member to give it a wash.IMG_2554_zpswoy1pfw4.jpg
Also changed the wheel decals to current gen ones. (still in red)
Current state (yes i keep a document with all this info) :
337.4rwkw @20PSI 98RON.
Factory Pearl Metallic Black (732G)
Chassis Manufactured: September 1989
Engine
Racepace Forged Stage 1 Motor (N1 Block)
-Block/Head inspected, water and oil gallery plugs removed, hot tanked, crack and pressure tested.
-Block bored and honed (strainer plate), decked to correct compression height, crank tunnel line honed to RPM specs. Strengthen weak points in the block (similar to N1 block)
-Oil galleries modified, tap galleries, fit thread plugs, modify water galleries, new welsh plugs.
-Conrods resized, bushes, replaced and individually honed to suit piston pins
-New OEM R34 GTR Crankshaft, rotating assembly fully balanced
-Race Pace Custom Forged Piston and ring set (86.5mm)
-Improved combustion chamber shape
-Nissan N1 water pump
-OEM Nissan gasket kit
-Race Pace custom main and big end bearings.
-RPM Circuit Cylinder Head : Replace valve guides/stem seals, cut seats, face valves, match chambers, surface, re-shim valve clearances to RPM specs
-New OEM Cam belt, new tensioner and idler pulleys
-Fully blueprinted, block painted and precision assembly
Apexi PowerFC & Hand Controller
Garrett GT2859R-9 (HKS GT-SS)
HKS Adj. Wastegate Actuator Kit
Tomei Metal Exhaust Manifold Gasket Set
Standard Airbox with Blitz Filter
Nismo AFM’s
Nismo 600cc injectors
Nismo In-Tank Fuel Pump
HKS Intercooler Pipes
Tomei Oil Pump
Racepace 9L Extended Sump – Baffled With Trap Door
SFIDA Oil Cooler & Greddy Thermostat Controller Oil Sandwich block
Ron Davis 3 Layer Alloy Radiator
Nismo Thermostat
Splitfire Coilpacks & New Coilpack Harness
Racepace Adj. Cam Gears
Tomei Expreme Dump Pipes>
Racepace 3”>3.5” Front Pipe>Racepace Spec CAT>Racepace 3.5” Catback Exhaust.
Drivetrain, Suspension & Handling
·         Nismo Coppermix Twin Plate Competition Clutch Kit
·         Nismo Engine & Transmission mounts
·         Racepace Rebuilt & Modified Transfer case & ATESSA
·         Volk TE37 17x9” +0 Gloss Black – Falken RT615 : 255/40/17
·         Volk TE37 18x9.5 +12 Satin Black – Yokohama AD08R 265/35/18
·         Racepace Modified Tein Circuit Master RE Coilovers. 8KG/mm Front | 4KG/mm Rear Revalved & Modified to Racepace specs.
·         Whiteline Adjustable Front & Rear Swaybars & Links
·         Cusco Front Upper Control Arms
·         Whiteline Cradle Bushes
·         Whiteline Adjustable Castor Rod Bushes
·         Front Brakes: D2 8 Pot Calipers & 2 Piece Slotted 356mm Discs, Braided Brake Lines, D2 Street pads
·         Rear Brakes: DBA 4000 Slotted Discs, QFM A1RM Pads
·         Nismo Front (Brake Master Cylinder Brace built in) & Rear Strut Braces
·         Racepace Reinforced HICAS lock bar. All HICAS hardware removed/re-routed correctly by Racepace.
Body/Chassis
·         Nismo Optional Genuine 3 Piece Side Skirts
·         Nismo Optional Genuine Rear Pods
·         Nismo Front Bumper Ducts
·         Nismo Bonnet lip
·         Nismo Boot lip
·         Ganador Aero Mirrors (motorized)
·         GKTech Air Deflector Panel
·         OEM Brake Ducts
Interior
·         Nismo 320kph Speedo
·         Sparco 353 Suede Steering Wheel + Sparco Dual Horn Button Kit
·         R34 GTR Front Seats
·         Nismo Duracon Shift Knob
·         Superior Auto Creative Sunvisor Covers
·         Superior Auto Creative Carbon Shift & Handbrake Boot
·         Superior Auto Creative Carbon Armrest Cover
·         Leather Handbrake Handle Cover
·         Leather Door Trim & Passenger Door Handle Covers
·         Carbon Coated Interior Trim Pieces
·         Fire Extinguisher & CAMS Approved Machined Bracket
·         Carbing Multi Point Roll Cage
Electronics
·         HKS Boost Gauge
·         HKS Water Temp Gauge
·         N1 Headlights - Philips Vision Plus H4 Globes
·         JVC Head Unit & MB Quart Reference 6.5” Component Speakers
Other
·         Brand New OEM Headlight Switch
·         Brand New OEM Left & Centre Air Vents
·         Brand New OEM Door Handles
·         Brand New OEM Centre Console & Glovebox Mats
·         Brand New OEM Radiator Support Bushes
·         Brand New OEM Brake Line A-Clamps
  • Like 4
Did you ever get results from the fuel sample?
Any ideas on original engine failure? Action taken to prevent a repeat?
We knew it was fuel contamination and apparently the sample wouldn't tell us exactly what it was so we didn't end up getting one.
Guess i'll need to avoid small town servos. Will take gerry cans with me track day. Almost makes me want to go e85, if I'll be karting fuel around...
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
