Who is this ash person.. such a bogan name...I just picture someone with a commo with stockies on it.
And chicken legs :ph34r:
But yeah, Kwaka rules the interwebz
where are you getting this garbage from....throttle bodies are completely closed you goose...until you push the accelerator air is bypassed through your idle control valve and that is what makes it run...when you push the accelerator the throttle body opens and air rushes into the engine cause the revs to rise so the car can move....its simple logic...but in your setup when i push the accelerator according to your "logic" there will only be a small amount of air in the pipe that wont last very long at all and thats assuming you have a leaky throttle body..so i very much doubt its going to last long enough to get the car up to a decent enough speed to create 6psi of boost in the intercooler.. I guesstimate this would take at least 20 mtres of driving...where is your air supply coming form for that 20 mtres?? and its going to take even longer to build up pressure if you have a leaky throttle body....
no throttle body is completely closed, or it would bind/seize with heat...
newer cars with electronic throttle bodies usually don't have iac's
Man I don't know if you guys are taking the shiat out of each other or if use are being serious, but fark this kawasakirider dude is taking the piss out of all of use and use are falling for it by the looks of it, dumb and dumber haha lol.
Use said it...
  • Like 1
haters be hating.
I'm taking some of these ideas and stepping it up.
have a efi motor to go in my stang as I doubt this would work proper on a carby.
however
going bigger capacity cooler
stiffer spring on TB
using a air -> water intercooler with ice in the reserve tank.
should be kick arse.
haters be hating.
however
Build thread?
Long story short.
bought worst car int he world including front wheels 6 inch different mounting.
.got everything fixed, took car in for new starter motor they blew engine and said must have been like it when brought in.
car sat 4-5 years, got drunk at bathurst bought ef falcon for motor
stripped car.
soda blaster coming in this weekend, then new motor paint cruise
oh and Chip foose did a sketch for me
I've received quite a few PM's asking if I could piece together N/A intercooler kits for people.
The answer is no...
1. I don't know what car you have, every car is different (front bar etc) you'll need to mount your stuff so it works, selling a generic kit is bound to generate complaints as I can't be sure it will all fit properly.
2. If you can't plumb an intercooler and a throttle body together, you shouldn't be working on cars. Just enjoy the 100rwkw that your car puts out without my mods.
Sorry to be harsh, but it's that simple.
Edited by kawasakirider
Nah mang. Use dun even no. Kwaka is straight up yo.
Only Juan?
I just told the whole of the N/A section how to gain ~40rwkw for $200 and still have change for beer.
Juan from me...I only have 1 a day to give out. I think everyone who has an N/A and wants to make 40+ KW should also give you some free internets as well.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
