Just some bits and bobs:
Rear housing off the rear of the turbo ready to be sent to HPC Coating:
920490-637780412902988-970992184-o-63778
476217-637780396236323-898132014-o-63778
Nitto H-beam Rods:
904732-637780426236320-204623195-o-63778
397927_637780426236320_204623195_n.jpg?o
ACL engine gasket, Nitto Head gasket and Cometic exhaust manifold gasket:
476352-637780436236319-1523615168-o-6377
Bolts and Studs:
922473-637780466236316-2099220442-o-6377
Where did you get your machine work done? They didn't use a torque plate for bore honing?
My mate at JDM Garage is doing the engine rebuild.
In regards to the torque plate, its a bit over my head but after some discussions involving the actual benefits of a torque plate we decided not to go with it. The theories were quite interesting..
Seeing the Nitto gear on display at the JEM tech night was good, having them explained etc was awesome! Such quality :woot:
Yeah I saw pics from your NSW JEM meet. Was very jelly
Really good motivation for ya ;)
Looking good tony! When she due back on the road?
Yeah this i would like to know! Should be good :yes:
I estimate that the engine will be finished with everything back in the car in about a month.
Then another month sorting out the VIV (As the car was written off) and Road Worthy Certificate.
We might have some issues with the engine gaskets. As we were supplied with a ACL Rb25det gasket kit not a neo one. Even though we were assured it would fit.
I already know the plenum gasket is different, among a few other things as well.
Anyone know where to get them quicksmart? Apart from getting them via Nissan or Japan?
I can get a full genuine Neo engine gasket kit from Amayama for ~$350. But its a 3 week wait and I would get a whole bunch of other gaskets I don't need.
Edit: Just emailed Andrew from Kudos to help me out
On 4/30/2013 at 9:31 AM, 34GeeTeeTee said:
I was going to say Nitto mentioned they had them in stock at that Tech night but i assume you would pay accordingly....
A complete Neo engine gasket kit? That's interesting, didn't know they made them :(
I got the Nitto Headgasket though
In any case getting a genuine Nissan gasket kit off Andrew @ Kudos motorsports. So props too him!
Also these just arrived today
Complete Genuine Nissan Heater/coolant hoses & thermostat for the Neo:
478539-640102536004109-1886260594-o-6401
Prett keen to hear the theories if you'd like.
I will ask and will post when he gets back to me :thumbsup:
In the mean time, just out of interest
Weight of:
Nitto rod & Cp piston = 944.4grams
Stock Neo rod & Piston = 1134 grams
So a saving of about 1.14kg in the engine by using these parts
923399-641111785903184-1666426285-n-6411
Weight of:
Thanks for doing that :thumbsup: Interesting!
Had a quick chat to the engine builder and most of it went over my head. But he said his happy to chat to you about it at any future SAU meet, whenever you guys see each other :thumbsup:
In other news:
Nitto crank collar fitted:
310016-641607085853654-585734729-n-64160
Grub screws fitted to the crank collar, crank is now finished ready to be sent for balancing
482642-643106392370390-976179864-n-64310
945469_643106305703732_634273494_n.jpg?o
Also weighed the CP pistons and Nitto Rods to see if any weight adjustments needed to be made:
Nitto Rods:
1. 516.0g
2. 516.5g
3. 515.8g
4. 516.3g
5. 516.5g
6. 515.8g
CP Pistons
1. 426.8g
2. 426.8g
3. 426.5g
4. 426.8g
5. 426.6g
6. 427.1g
Block has been peppered:
919436-652171204797242-1485976487-o-6521
976373-652171188130577-1145389192-o-6521
Also genuine gaskets arrived today. Many thanks to @kudos.motorsports
944737_643106412370388_654822655_n.jpg?o
  • 3 weeks later...
On 5/22/2013 at 7:43 AM, Leroy Peterson said:
any updates?
Coincidentally yes I do!
Block and head is all finished. Just waiting for the crank to finish balancing then its just assembly and to put the engine in!
Hopefully only a few weeks away and the engine will be running in the car!
248104_651224698225226_708561579_n.jpg?o
Also have received my brae manifold, turbo housing and dump pipe all HPC coated. Only a one week turnaround:
All nicely packed in delivery by HPC:
977959-651224998225196-118991215-o-65122
976922-651224784891884-1119670989-o-6512
965739-651224798225216-1967956834-o-6512
967093-651225041558525-194920362-o-65122
980496-651224864891876-518724312-o-65122
977990-651224951558534-758279348-o-65122
For those that are interested we also decided to lay the "torque plate" theory to the test as we had some spare time. We torqued the head down to 80ftb using arp head stud, flipped the block over and measured the bores. No distortion was present and the bore gauge still read 0.
970616_651224994891863_216125180_n.jpg?o
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
