So much mirin Toby
Dark rims suit it I reckon!
Yeah dark rims are good
At the moment the current rims aren't wide enough
And I can't fit spacers at the moment even up to 25mm as the rim hub still hits the old studs
hot dam that paint is gorgeous, it just gets better and better
Thanks scmate!
shiiiieeet can't wait to see in person
Soon Leroy! Soon!
Down at OTR to fit a set of 265/40/18 Hankook Rs3 tyres
Big range of rims and friendly bunch of guys.
1500786-767654359915592-1630476257-o-767
Tried some Te37 SL's 18 x 10.5 + 15 for fun. They have an Advan 050 295 tyre on them i think
1486051-767654363248925-3673169-o-767654
1502900-767654343248927-375397347-o-7676
1471263_767654363248925_3673169_n.jpg?oh
1466217_767654343248927_375397347_n.jpg?
Hankooks on
1501024-767654389915589-2129078233-o-767
Front tyres are scrubbing the top bit of the suspension so I need to go either a 35 profile tyre or somehow fix the problem
On 12/9/2013 at 6:27 PM, owen1r said:
Hnnng those TE37s are hot, awesome colour combo maybe you should treat yourself for christmas?
Ahh thanks mate. Spending that much on rims is out of my price range at the moment. I don't mind TE37's but prefer them in 19's with the dish!
So this is what happens when you run too chunky of a tyre. Suspension arm/knuckle is touche the tyre. Might need to angle grind it down for more clearance
Also I did play around with the idea of white writing on the tyres after seeing one on a hankook race car. But decided not to go ahead with it haha
1167417_768541539826874_1796915530_o.jpg\
1167417-768541539826874-1796915530-o-768
Ah, I see now.
That's the camber arm, not the knuckle. Just cut the arm down.
If you really want, buy a offset bush and offset the arm higher. It will clear easy that way.
Oh i forgot to say that pic is with a 8mm spacer that I was trialing
Oh thanks. I have no idea about suspension bits lol
Might look into the offset bush if it is also a cheap solution
Are there other bits I may as well change at the same time if I change the bush?
Suspension is stock except for coilovers, so would like to do a few things to improve the handling before the next track day
I know I probably need front and rear adjustable camber arms for more negative camber
On 12/11/2013 at 6:48 PM, Count Grantleyish said:
Isn't 40 profile bit too tall for Skylines? Most run 35 profile.
Yes it is a bit tall haha
Test fit of XD9's 18x10 + 18 265 Achilles tyre. Plenty of clearance
I don't mind Xd9s...
902351-768766373137724-320856539-o-76876
10750324-958603354154024-226993447194029
1401516-958603400820686-7929943015456419
  • Like 2
On 12/11/2013 at 7:37 PM, Count Grantleyish said:
How many wheels have you trial fitted so far?
Hehe just borrowing a friends wheel for now till i fix the issue
If anyone has any Ce28ns I can trial fit...
This is the clearance I have with the Xd9's 265/35 tyre combo
1000117-768792159801812-1283234871-n-768
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
