So much mirin Toby
Dark rims suit it I reckon!
Yeah dark rims are good
At the moment the current rims aren't wide enough
And I can't fit spacers at the moment even up to 25mm as the rim hub still hits the old studs
hot dam that paint is gorgeous, it just gets better and better
Thanks scmate!
shiiiieeet can't wait to see in person
Soon Leroy! Soon!
Down at OTR to fit a set of 265/40/18 Hankook Rs3 tyres
Big range of rims and friendly bunch of guys.
1500786-767654359915592-1630476257-o-767
Tried some Te37 SL's 18 x 10.5 + 15 for fun. They have an Advan 050 295 tyre on them i think
1486051-767654363248925-3673169-o-767654
1502900-767654343248927-375397347-o-7676
1471263_767654363248925_3673169_n.jpg?oh
1466217_767654343248927_375397347_n.jpg?
Hankooks on
1501024-767654389915589-2129078233-o-767
Front tyres are scrubbing the top bit of the suspension so I need to go either a 35 profile tyre or somehow fix the problem
On 12/9/2013 at 6:27 PM, owen1r said:
Hnnng those TE37s are hot, awesome colour combo maybe you should treat yourself for christmas?
Ahh thanks mate. Spending that much on rims is out of my price range at the moment. I don't mind TE37's but prefer them in 19's with the dish!
So this is what happens when you run too chunky of a tyre. Suspension arm/knuckle is touche the tyre. Might need to angle grind it down for more clearance
Also I did play around with the idea of white writing on the tyres after seeing one on a hankook race car. But decided not to go ahead with it haha
1167417_768541539826874_1796915530_o.jpg\
1167417-768541539826874-1796915530-o-768
Ah, I see now.
That's the camber arm, not the knuckle. Just cut the arm down.
If you really want, buy a offset bush and offset the arm higher. It will clear easy that way.
Oh i forgot to say that pic is with a 8mm spacer that I was trialing
Oh thanks. I have no idea about suspension bits lol
Might look into the offset bush if it is also a cheap solution
Are there other bits I may as well change at the same time if I change the bush?
Suspension is stock except for coilovers, so would like to do a few things to improve the handling before the next track day
I know I probably need front and rear adjustable camber arms for more negative camber
On 12/11/2013 at 6:48 PM, Count Grantleyish said:
Isn't 40 profile bit too tall for Skylines? Most run 35 profile.
Yes it is a bit tall haha
Test fit of XD9's 18x10 + 18 265 Achilles tyre. Plenty of clearance
I don't mind Xd9s...
902351-768766373137724-320856539-o-76876
10750324-958603354154024-226993447194029
1401516-958603400820686-7929943015456419
  • Like 2
On 12/11/2013 at 7:37 PM, Count Grantleyish said:
How many wheels have you trial fitted so far?
Hehe just borrowing a friends wheel for now till i fix the issue
If anyone has any Ce28ns I can trial fit...
This is the clearance I have with the Xd9's 265/35 tyre combo
1000117-768792159801812-1283234871-n-768
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
