So installed the oil cooler at Scotty Customs yesterday.
Didn't have time to do any ducting but might be ok, well see!
Will be curious to see what temps it does at Phillip Island
On street driving
Highway temps on a 25c day
Before: 98 degrees
After: 80 degrees
10929096_1009459115735114_79092875403676
Test Fit along with fitting a tow harness
1461672_1009458529068506_330859153414156
Fitting Greddy oil thermostat opens at ~ 80degrees
10917815-1009458649068494-54235615736247
All done:
10923572-1009458622401830-24021783738485
10942627_1009458582401834_77675653453008
1939497_1009458549068504_274021022972297
10868086-1009458742401818-22703895659122
  • Like 3
looks great tony, cant argue with those massive improvements on temps, almost convinced to replace my oil cooler with one.
hey on a side note, what front mount are you running? i really cant be bothered searching through 15 pages to find it. cheers mate.. still loving the build as always! :cheers:
very nice.
at least you let him take the bumper off to fit stuff......
Is there a joke going around that I don't know of?
Why wouldn't someone let Scotty take off the front bumper if your working on the car :/
The intercooler came with the car when i bought it many moons ago.
Pretty sure its just a stardard HDI cooler. Not sure what spec though.
I'd only consider having an oil cooler if your were tracking the car.
Be hard to get over 120c consistantly on the street lol
So anyone running an aftermarket manifold may have this issue:
Heater core hoses running up hard against the manifold:
10931384-1011365998877759-97400173380485
Quick fix by Mikey @ JDM Garage:
10686901-1011365982211094-56523640301664
Now have massive amounts of clearance
Might put some heatshield in there anyway as I have a whole sheet spare to use
  • 3 weeks later...
So first track day of the year.
Had a few issues with old spark plug melting, then a massive boost leak.
Best time of the day from me was a 2min 07. Only managed about 2 full sessions :/
Was a great experience though!
10923264-1021991654481860-33436983888742
10986845_849414088437535_580831394374264
10923264_1021991654481860_33436983888742
10978597_1021991684481857_13670802999942
Got home, decided to try and find the boost leak:
30mins later..
10425050-1021991571148535-51690043937634
10980757_1021991594481866_48806728583924
Also new Cusco camber arms and tension rods came in the day after the track day of course.
I think this will be the last mods on the car for a while, and ill just concentrate on track seat time:
10806490-1021991554481870-50100739818297
damn, tough luck. BKR7's too :/
howd the teins hold up? tyres grip ok? oil temps?
I thought suspension wise the car handled ok
Oil temps from what I saw never went past 105-110c after 4 hard laps. But ill review the footage, never pushed the car past the limits of the tyres i dont think
I got Richo to do a test run, ran a 2.03 with massive boost leak and in traffic, he thinks the car has at least another 10 secs in it. Said my tein HA's are ok but has no rebound or dampening
On 2/10/2015 at 7:22 AM, gtr jet said:
Maybe I should get Richo to do a test run in my car. Would love to see what it's actually capable of.
Should be plenty of time at Winton :thumbsup:
Ok new hoses have come in to replace some torn and worn ones:
10978577_1023508987663460_50941772456731
Ill put them on the weekend.
Next track day booked for Winton 14 March
I'd be happy with a 1:45. Only second time there. And really only my 4th or 5th track day in 3 years
Will try and the Cusco arms and tension rods put in before then
  • Like 1
  • 1 month later...
So minor update
Spark plug in cylinder 3 after a few km's of driving:
11082501_1048810628466629_52652674156252
Compression test on cylinder 3. 150psi. Rest where about 180psi
Pulled the head off.
Did notice some black goo in the chambers. Not sure if concern yet
11014810_1048810548466637_41510956770430
Pulled the head apart:
Something not quite right, one port looking brand new:
10603328_1048809488466743_21801098336751
Vacuum tested the ports:
10473639_1048811075133251_63341654075037
One port something funky going on:
11014810-1048810548466637-41510956770430
Pull out the injectors, black goo covering on of the injectors:
11064900-1048809281800097-23656845259077
11075297-1049642378383454-63030722592499
Dat e85 life
Hmmmmmmmm test and clean the injectors while they're out?
Yeah going to get it flow test and cleaned
What injectors are they? Looks like that one could be stuck open or something.
Bosch EV 14 1000
Did a search on SAU and apparently other people have this issue:
Washable stainless filters are not fine enough, the dreaded black gunk seems fine enough to get through them and clog the injectors. I was recommended to install 10 micron paper elements to guarantee it would catch the black crap present in e85. (I assume from the manufacture of the fuel.) Moran refuse to warrant their injectors without a similar filter fitted in the fuel line...
E85 is a great cleaning solution and should flush any varnish buildup through, but this can block the filter internal to the injector, which in the EV14's is nearly impossible to clean.
Yep.
I just fitted 3/4 length Xspurt 2000's in it's rail due to the 1000's blocking with that black gunk. I also fitted a 10 micron paper element filter to trap any further crap in the fuel. It's not the first ethanol car to show these blockages, although mine has been fine.
There is extensive talk on it on these forums:
http://codsm.org/forums/showthread.php?t=3965
uote:
Alright, I finished my analysis of this stuff, and my finding is very unexpected. I think it will
probably surprise everyone else as well. This doesn't appear to be forming because ethanol
is "such a good solvent" but because ethanol is a poor solvent. I suppose it should have
been obvious when others said that it "washes right off with gasoline". Why would
something that ethanol is selectively dissolving wash off with gasoline? If this were
something in rubber or from our fuel tanks, wouldn't that imply that gasoline would dissolve it even more readily than E85? Alright, so what is this stuff? It is a appears to be a very large petroleum based
hydrocarbon, similar to Vaseline. There isn't a single hetero-atom in the molecule (ie, the
entire molecule is comprised of hydrogens and carbons), but the molecule is very large. It is
also completely aliphatic (ie, only single bonds in the structure - no double or triple bonds).
Where did it come from? I can only think of two different sources it could be coming from.
It is either something that is mixed in with the rubber hoses that is meant to dissolve away in the gasoline, or it is a trace impurity in the 15% gasoline that is in E85 that wasn't
separated during the fractional distillation process. Because it is such a large molecule, it
wouldn't be very soluble in ethanol and could easily crash out of solution at the injector.
Quote:
So, let me see if I can wrap my decidedly non-chemist brain around this: This "very large petroleum based hydrocarbon", or vlpbh , is able to be completely dissolved into gasoline, essentially becomes part of that fuel, and is burned up in
combustion, never to be seen again except broken down as part of the exhaust gasses out
the tailpipe. However, with ethanol, the vlpbh is more or less "dislodged" from the rubber or
distilled petroleum, and is carried by the ethanol as a separate particulate of sorts, perhaps
partially burning during combustion (that which makes
I think they are looking at it from the wrong end, I believe it is carbon coming back from the combustion chamber, as the intake valve opens. Similar thing happens in direct injection motors as the petrol isn't cleaning the runners.
It is not in the flow path as the ethanol pushes that out the way. The modified 1000's are actually good for this, as the tip isn't large enough to gunk up too much. I doubt there will be a flow difference unless the filter inside the injector is blocked.
Those 1000's I mentioned above had a little filter added in the top, which was the likely cause of the flow issue he had. I never run those little secondary filters anymore, they are too fine and block up easily.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
