Piggaz Posted September 23, 2014 Share Posted September 23, 2014 Kw Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7395306 Share on other sites More sharing options...
lcxu105 Posted September 23, 2014 Share Posted September 23, 2014 What if I run bp98 fuel Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7395354 Share on other sites More sharing options...
scotty nm35 Posted September 23, 2014 Share Posted September 23, 2014 You should probably stick to the GT variant then, as it is more efficient at the lower boost you will need to run. Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7395363 Share on other sites More sharing options...
lcxu105 Posted September 23, 2014 Share Posted September 23, 2014 I currently run 20psi with the bp98. I also run c5 booster mix 1 can to 30lt fuel Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7395369 Share on other sites More sharing options...
lcxu105 Posted September 23, 2014 Share Posted September 23, 2014 Looking at upgrading from my hi flowed op6 to the gtx3071r. Or the gtx3076r. Want to make 420 to 450hp@rw. On pump 98 Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7395404 Share on other sites More sharing options...
M@&k Posted October 11, 2014 Share Posted October 11, 2014 Ok, so I've had some more work done to try and eliminate things which might be holding the GTX3067 back: * Dump pipe changed from split dump to bellmouth * Actuator changed from 8psi to 18psi * Replaced cat (which was an older model high flow) with a 100 cell high flow After the dyno run to check power etc, the sum effect of the above was... zero. No change in peak power, no improvement in boost threshold. Tuner said boost control is much better now, and that the dump pipe no longer gets as hot. His recommendation next is to change out the turn-flow intercooler, but I'd rather look at mods for better response first if anything. Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7406074 Share on other sites More sharing options...
M@&k Posted October 22, 2014 Share Posted October 22, 2014 I've tried getting my hands on a 0.63 A/R IWG housing, but have been told no stock in Australia and Garrett is no longer manufacturing. I believe Disco mentioned this before too. Option now is to source from US, or second hand (annoyed I didn't get the one AngryRB was selling now). Only US supplier I really know of is ATP turbo. Any other suggestions? Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413031 Share on other sites More sharing options...
wolverine Posted October 22, 2014 Share Posted October 22, 2014 streettotrack.com Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413037 Share on other sites More sharing options...
AngryRB Posted October 22, 2014 Share Posted October 22, 2014 (edited) If it were me id be keeping the housing and sending the turbo to FP , turn it into a HTA3073 and dump the turn flow intercooler, ive got the piping from intercooler to throttle for sale, could be done cheap. Edited October 22, 2014 by AngryRB Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413442 Share on other sites More sharing options...
M@&k Posted October 23, 2014 Share Posted October 23, 2014 Funnily enough I've been thinking about the HTA3073... but not ready to spend on changing turbo's again just yet. I'm actually pretty happy with how it's going at the moment, just it's always been bugging me about what it might be like with the 0.63 housing, which it probably should have had from the beginning. Will see how I go sourcing a housing first. What style piping do you have? Goose neck over the cam covers? Or over the radiator shroud? Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413461 Share on other sites More sharing options...
discopotato03 Posted October 23, 2014 Author Share Posted October 23, 2014 I would lean towards getting the turbocharger right , I use the same IC and my at the time GTRS on its knees made 271 at the bags . Back then the tuner said boost pressure fell from 17 to 14 indicating that it was choking on the hot side . A . Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413475 Share on other sites More sharing options...
AngryRB Posted October 23, 2014 Share Posted October 23, 2014 (edited) The one that goes across the radiator, not the best but works. I've gone the plazmaman plenum. Maybe hypergear has a suitable housing that could bolt onto your turbo? Edited October 23, 2014 by AngryRB Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413482 Share on other sites More sharing options...
M@&k Posted October 23, 2014 Share Posted October 23, 2014 Having had the dump remade twice now to suit this Garrett housing, I'd be reluctant to change dump pattern again. I'd still keep the 0.82 housing in case of later upgrades (e.g. to HTA3073). Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413521 Share on other sites More sharing options...
Ben C34 Posted October 23, 2014 Share Posted October 23, 2014 http://www.procharge.com.au/online-store/turbochargers-performance/turbine-housings/gt3035r-iwg Isn't that what you are looking for? Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413535 Share on other sites More sharing options...
M@&k Posted October 23, 2014 Share Posted October 23, 2014 It sure is, and I tried to buy it through them, but they refunded my order saying they couldn't get any stock. Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413549 Share on other sites More sharing options...
Ben C34 Posted October 23, 2014 Share Posted October 23, 2014 It sure is, and I tried to buy it through them, but they refunded my order saying they couldn't get any stock. I absolutely hate it when they don't update their stock when they know they have none....... ass holes! Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413552 Share on other sites More sharing options...
M@&k Posted October 23, 2014 Share Posted October 23, 2014 They didn't realise there wasn't any available until they tried to fill my order. I got the impression they ship direct from Garrett Aus and don't hold stock themselves so they weren't aware there wasn't any stock in the country. He said they'd update their website now they know. Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413636 Share on other sites More sharing options...
Lithium Posted October 23, 2014 Share Posted October 23, 2014 There are bound to be some somewhere, maybe worth giving these guys a shot if you want to go there. http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-037&Category_Code=GTH Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413667 Share on other sites More sharing options...
M@&k Posted October 23, 2014 Share Posted October 23, 2014 Have contacted Paul from streettotrack as per Wolverine's suggestion. If no joy there, and no other options, will try ATP. Any idea how much shipping would be? Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413679 Share on other sites More sharing options...
scotty nm35 Posted October 23, 2014 Share Posted October 23, 2014 A lot, perhaps $100us. I thought you wanted more power from it, not less? Link to comment https://www.sau.com.au/forums/topic/419955-looks-like-garrett-slipped-another-gtx30-variant-in/page/17/#findComment-7413681 Share on other sites More sharing options...
