Hey guys,
A bit of a query. If I was to replace stock skyline discs with after market items (cross drilled, slotted etc) but without upgrading anything else in the braking system (so calipers and lines remain stock but maybe get some better pads), would this actually prove to be beneficial or must the whole system be upgraded. I know that changing calipers etc is better but I just wanted to know whether changing discs on their own is worth while and will provide better braking.
cheers
https://www.sau.com.au/forums/topic/420284-upgrading-discs/
  • Replies 43
Changing just rotors wouldn't make any noticeable difference. Cross drilled can crack in heavy use. In theory, slotted are better at removing the gases that the brake pads release making the surface contact better, but i cant say i can notice the difference.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-6760591
Not sure mate but I guess the question applies accross the board. Is upgrading discs on their own worthwhile?
Doesnt seem so :unsure:
I may be wrong but alot of track cars dont tend to use the standard brake rotors.
Trackwork = Yeah a little bit.
Street driving = Nah.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-6760805
Upgrading to slotted discs and better pads will make a big difference,.
Slotted rotors are benificial on both on the street and track (more so on the track).
If your going to do rotors you need to do pads though, stock pads are rubbish, Im using TRW at the moment and they are a massive upgrade from stock, I'm still on the stock rotors though.
Theres no need to upgrade your calipers unless your doing alot of track work, the stock calipers are fine for 90% of people.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-6761183
slotted rotors also chamfer the brake pad constantly, giving a nice fresh surface.
the slots, stop the build up of gases and such between the contact areas.
there isnt really a benefit to running them on the street unless you do a lot of mountain/twisty rd driving where you use the brakes alot.
as mentioned, better pads will make a decent difference.
fresh fluid will also help delay boiling.
ss lines stop flex.
all very little differences that add to a whole.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-6762966
  • 1 year later...
Would there be a noticeable difference in stopping power going slotted dba's over standard rotors
I'm doing my brakes in the next week or so and am tossing up. If dba slotted rotors are worth it. Rotors aren't bigger and the calipers have the same clamp force so would it do anything
This is what I'm thinking
Option 1
DBA 4000 SLOTTED ROTORS
HEL BRAKE LINES
GOOD PADS
GOOD FLUID
Option 2
MACHINE OEM ROTORS
HEL BRAKE LINES
GOOD PADS
GOOD FLUID
Would buying dba rotors be worth the extra $600?
What do you guys think? car is mostly used on the street( in a controlled manner) with plans of a few track days in the future.
Also I was reading this http://honda-tech.com/showthread.php?t=1437513 I'm not sure it is from a Honda forum, but sorta makes sense. What do you reckon?
Give me your thoughts guys
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-7291347
hahah knew that would come up :P
they're still going strong though, the metal removed makes no difference and solid as a rock. They're still left with more meat than lightweight racing calipers (more than my Wilwoods anyway)
GK Tech sell the caliper adapters, easy enough to do.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-7291620
Most of the adapter brackets that have been done for R33 calipers onto 324mm rotors require grinding the caliper to make it sit down on the disc better. Otherwise the pads overhang the edge of the rotor, which is not nice.
Some people on here are fine with that. I'm not so much. Hence why I haven't done it.
By the way, if this is mostly a street car, you won't really notice much benefit from bigger discs anyway. You can already lock your wheels up with what you have, therefore you cannot actually brake harder than you can now. All that bigger rotors give you is a change in bias, extra mass in the rotor so they resist fade under continuous hard braking (like track work), more braking torque per unit of pedal pressure (so they feel like you can brake harder, but as per previous mention, you can't really) and the small potential for a defect if they're not engineered and they're found during an inspection.
For a streeter, new rotors, better pads, good fluid, braided lines and a master cylinder stopper are sufficient to make a big difference in real performance and feel. You still can't actually brake any harder unless the original brakes are in such poor condition that you can't lock it up.
https://www.sau.com.au/forums/topic/420284-upgrading-discs/#findComment-7291627
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
