After some last minute, late night shenanigans my car finally got back on the road (after 6 months sitting in the backyard). What should have been a quick tune turned into a 6 hour adventure, with the std GTR injectors maxing out, then a hidden CAS ground wire becoming unearthed and not being discovered for 90mins (we thought the CAS died, and were awaiting a replacement to be delivered).
There was no EBC fitted as I wanted it to be wastegate only, but there seems to be some funky problem with the wastegate holding boost - even wound in fully to 1.2 bar.
Car's mods:
Custom spaghetti low mount turbo manifold
HKS 3040 .73 A/R
Trust type R wastegate
Greddy plenum
Aftermarket metal head gasket (unknown thickness)
Q45 t body + AFM
Trust 115mm intercooler
Sard 700cc injectors
HKS 256 + 264 reground copies (have a master now, can do these at will)
Full 3 inch Nismo exhaust, no center muffler
Will be setting up an SBC ID 3 tonight for another late night marathon, the car was detuned from this run to cope with additional boost, and more low rpm boost as well.
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/
  • Replies 70
Tah Phil, I forgot to mention the tuners - it was done at Unigroup by Judd's pimped out tuner. I was impressed by the amount of additional features were on the software - Val and Chris @ Unigroup were genuinely nice people, even staying up way past their bedtime to finish it off. Jimmy is pretty good at tuning too, would be great if he could set up shop in Sydney permanently! While the guys were trying to pack up and close the shop Jimmy was still hard at it, trying to get anti-lag working well - would definately recommend the combination of Unigroup + Jimmy on a PowerFC controlled car.
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861045
yes...happy to hear another one happy about Jimmy's tune..
I was a bit worry at another thread when I mentioned a Apexi software tuner come to town, because I just worried my arxx get on the fire line, but good to see good result come..yes, I will ask him to setup the anti lag thing on my car too..wooooh..
Just a quick question, would not 264/264 provide you better middle range? or you have some plan in mind? also do you have the A/F print out?
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861119
Chris,
I just hope it is a simple waste gate issue although the signs point to that not being the case :)
But that was a roller coaster of a night, from the welding to the cas to that power steering belt, I haven’t had a night like that for ages.
But the car definitely has the goods to make a lot more with what it has now.
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861151
Well what takes 5 mins with the HC takes 30 seconds with the laptop. The ability to change injector pulse width modulation at certain rpm’s, graphical display for all the parameters and overall control of every parameter ala motec/autronic makes it a top bit of kit.
A shame it cost $$$ and it’s all in japanese :) But at the end of the day, even with a HC, if you know what you are doing then it will do the job :)
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861182
Looking good. Certainly a good all round package with nice power. With that housing I would have thought boost might come in a bit earlier and hit a bit harder?
I noticed you are using a Nismo exhaust? I had the same, and it choked the car a fair bit. when I upgraded to a HKS super dragger I found more power everywhere and boost came in around 800rpm earlier with much crisper throttle off boost too. Easy to tell if it is hurting, just dump the exhaust off for a dyno run:)
the boost response seems similar to my 3037 until around 7-8psi, so I am sure the EBC when it goes on will help. How do you have the wastegate plumbed at the moment? what size gate, what size spring?
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861368
Steve: It has the middle muffler taken out, it's basically a 3 inch all the way with only the canon at the back. No idea about spring rate, or the diameter off hand. Oh and it's a screamer pipe (sounds pretty funny with a different note when it goes above 6500-ish rpm)
Sideway: Yeah, 264's would be better. This car was assembled late at nights using parts lying around the garage, they are the only RB25 cams here.
I think the tuning work was good, but I am looking for a very steep curve for that turbo kick.. hopefully the SBC will fix that. Can't be assed working out wtf is actually wrong with it, have no time and the SBC looks like it will be a big bandaid with the least amount of time to install.
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861411
Great to see it running Chris, it looks like it has a little wastegate leak (up to 6,000 rpm). Until the airlfow gets so high (over 6,000 rpm) then the little leak doesn't matter. It should get to 18 psi before 5,000 rpm I would have thought, that 6 or 7 psi will make a huge difference to the curve.
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861417
Bye-bye 2530, hello scary power, remember the Late Show and Mick Malloy in Sh1t Scared? Its not too late to go in the Dutton, well if not NSW then Vic :(
Whats all this talk about anti lag and PFC??? I have to come back to Sydney to get my car registered, before June 27 , if i can get my hands on a PFC in the next 2 weeks i may treat the old girl to a PFC instead of re-map :)
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-861758
When you look at those two curves together, they have "potential" written all over them! It's going to be interesting to see what the power curve will be like, considering the boost that's still to be had in the mid range :)
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-862035
Man - I just sat down for 1/2 and hour comparing Chris' to mine and I came out of my thinking with more questions than I first came in with - I need to gather my thoughts etc before I go asking questions -
But we have very similar setups amd here is mine...
You don't seem to get the big kick that i get - but top end is not that much different - but when I look at the rev range - I seem to get more down low...
Interesting.....
https://www.sau.com.au/forums/topic/42059-rb25-hks-3040/#findComment-862095
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
