  • Replies 214
Last time I wore shorts with length, they tore from balls to ass during an ATG squat.
Basketball shorts all the way mang. Best gym wear I've ever worn. Really gotta get myself some more next time I'm in USA lol
Well, here's my effort.. Like said have to use dumbbells. Shit cam angle sorry - no one to film so its resting on a bench against my bottle. I kinda took it slow.. Probably for the worse.. Yeah I know its not touching my chest - should I aim for it to with dumbbells?
I'm 79.8kg morning, 82ish night, 40kg dumbbells. 13 reps
http://www.youtube.com/watch?v=cKehJI6O_iQ
Get those bad girls lower! I reckon you need to at least touch the plates of the dumbells to your chest.
When you think about it, with the way you are doing it in the vid if that were a barbell you'd be a fair few inches from your chest still...
Good effort 10_4; dumbells aren't easy.
I also agree with Mitch; the dumbell plates should at least touch your chest. Bringing them lower will make you stronger at the exercise too :)
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
