So after running around on five cylinders and a boxer-like rumble for a few days, the verdict came back that an injector has died, which Nissan say is an $800 fix with a month's wait to get one shipped ex Japan.
Now, I suspect that &450 for an OEM injector is a bit silly, and I could probably get either mine or a secondhand part reconditioned for much less, or a full set of new ones for slightly more. A quick yellow paging has turned up B&M Fuel Systems in Richmond, does anyone know/recommend anywhere else?
https://www.sau.com.au/forums/topic/421266-fuel-system-specialists-know-any/
R33 GTS25 (S1)
I'd think that lots of people would have standard injectors hanging around for GTST's... since they upgrade them to bigger units, but less would for NA's....
Good luck mate, that quote from Nissan is stupid, ignore it and buy local / second hand.
You will likely get a brand new set of upgraded injectors for that price! Nissan know very little about performance cars :P
I hope you're implying he should also purchase the equipment required to support upgraded injectors too :thumbsup:
OP, I'm curious as to how it was diagnosed as a faulty injector? It's pretty unusual for an injector to go like that. Have you sussed out the ignition system first to make sure it's not a coilpack/loom/spark issue?
If it's the injector, you could probably take them all out and get them reconditioned / flow tested for $200 or so.
That's what I thought too, even supported by some quick searching under 'why does my skyline sound like a boxer?', but they tested all the plugs and coil packs and they were fine, compression tested the block and still nothing, then looked at the #6 injector as the source. Took them 5 hours to figure it out apparently.
Spoke to B&M this morning, if I were smart enough/had the tools to remove it myself, it would cost $40 to recondition the dead one, or $120 for a replacement.
2+ hours of labour, they aren't the easiest things to remove / install... There's $250...
Verdict's in - $120 for a reco'd piece, or $190 for a new one with a days wait on parts. Much better than $460 and a month ex Nissan, Odium, you're right - I'm looking at a few hundred in labour.
She'll most likely be going to the farm in 12-18 months so I'm just replacing the dead one and hoping for the best. Are in-fuel injector cleaners worth using?
Aznew charge $25 I think to clean and flow test an injector. Don't bother with in-tank injector cleaners, the mesh filter in the top of the injector is most likely blocked.
If you remove the injectors, make sure you replace the orings.
So i've finally got her back, and it's not what it seems.
Injector - Fine.
Coil Pack - Fine.
The culprit? The plug into the coil was corroded to hell, and had corroded the wire into the plug away completely. Real pain, and about $800 in labour to fix.
Which brings me to my next question. Given the fact that it was misdiagnosed by nissan service, and having them repair it wouldn't have fixed the problem, and the actual cause was something that (according to B&M) should really have been picked up on if a decent look was had into it before deciding it was an injector, and subsequently not testing the injector to confirm it, how likely would I be to recoup some of the costs from nissan service, given they have a three month warranty on their work?
Yep, given I was told it was an injector issue, I had it booked to replace. Didn't find out what it was until he'd pulled it all apart and tested the injector to find there was nothing wrong with it, so then he had to reassemble the whole show to troubleshoot it from scratch.
Half the cost is in removing and refitting the injector that was apparently busted. So the dealers wrong diagnosis cost me $500, when you include their bill.
I'll take it up with them, hopefully they'll be decent about it. Only sure thing is not asking guarantee's nothing.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
