Doing things properly (by that i mean technique aimed at the most efficient lift) then grip doesnt fatigue first. Your back does.
If you are using straps you are maybe performing the movement a little differently.
I would prefer to use fat grips and train grip strength personally.if grip was really an issue
Edited by rev210
This grip thing is quite amusing. Obviously that guy trains in a gym where lots of people use them and get good results, so he is for them, nothing wrong with that at all.
I have a gym where no one wears them, so I am against them.
Now I dont know what kind of weights the members at his gym lift, so I cant comment, but I do know what guys at my gym lift without them
310kg - Jack Pollard
300kg - Zoran Jankovski
290kg - Martin Nguyen
287.5kg - Nick Rankin
275kg - Daniel America
267.5kg - Nick Haralambopoulos
260kg - Max Markopoulos
260kg - Spiros Markopoulos
245kg - Conor Zyskowski
240kg - Alen Pezerovic
240kg - Lee Gamble
Way more, but you get the point. Dont assume everyone needs straps, let lifters choose, but its only fair to show them if you train correctly over a long period you wont need them.
If your concern is reps, here is Martin deadlifting triple bodyweight for 6 reps without grip issues
  • Like 1
Means sweet fa when he spits 3 discs out of his spine
Good luck I hope he never goes thru that as I've seen quite a few who never lifted again after doing stupid shit like 500lbs shrugs with bad ass form
Keep it safe, hard to tell a young ego filled and god knows what else junior (been there done that)
But your back..,, you only get one,
I trained with good form (most times) and still have life long nagging injuries now
Interested to see what you think good form is... Post a vid?
That to my eye looks nigh on perfect, biomechanically for a dead.
You are also speaking about a world record holders form for your info. Perhaps his trainer can comment?
Ok maybe I see things as a bodybuilder who believes in good form to isolate the muscles not sloppy powerlifters form
Shoulders need to be back chin up and no rounding off the back with a slight arch at the top and quick pause.
I never really focused or loved the deadlift like you powerlifters in here I did it when I wasn't squatting I found both in the same week to taxing
I still managed 200kg approx for 5 by the time I was 19 with strict form
This is an interesting opinion.
We aren't dealing with a beginers technique here. Powerlifter or not ,deadlifting isn't a simple movement at advanced weight levels. Bodybuiders are arguably not the most concerned bunch of people when it comes to form over muscle stimulation. A powerlifters livelyhood is based on being able to compete. One might think it's of greater interest to minimise muscle injury and maximise strength development through perfection of technique?
Chin up or neck tucked in is debate worthy (your vid posted is very tucked in, this provides better neutral spine at the expense of losing a slightly stronger upper back contraction in the case of chin up). He has scapular retraction, you can see it. The rounding you are refering to is in the upper back , not the lower. Thorasic mobiltiy as it is otherwise known is key to this movement.
Thats fair enough. What you are or were interested in is personal preference . Perhaps there is opportunity to evalutate your position on deadlift form, in light of some debate and information? I've found some view changing ideas come from Marko's experience and others, with training technique that applies across goals. Be it body building or powerlifting.
You said you picked up some war wounds from training.. how old are you now? Good to have some sobering insights for the younger gen.
His chin is up until the end not sure why he dips his chin right at the end lol
The other guy doesn't nor the other countless videos that came up instantly
33 started bodybuilding when I was almost 15 went hard till I was 25 since then I had kids and been on and off
I agree with rev...powerlifter form is hardly "sloppy". Form may be slightly different to conventional, because that's what happens at te extremes of lifting heavy weights. Form at 300kg is not the same as form at 150kg. It's in their interests to protect their bodies and safely lift as much weight as possible.
I don't see how you can have had back injuries in the past and be criticising the form of a WR holder, who lifts more weight at less bodyweight than you ever did, without the injuries you incurred? It's like someone from my basketball team trying to tell Lebron how to make a play...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
