90kg x 10
110kg x 10
140kg x 7
160kg x 3
Bit of a setback in training after my holiday in Perth and two subsequent colds. Earlier this week I pulled:
90kg x 10
110kg x 10
140kg x 6
160kg x 2
Next session will give 150 for reps a go, followed by 160 or 165 for reps.
So today my gym held a deadlifting competition as part of its open day, which I thought was pretty cool. Apparently they will be doing things like thia on a monthly basis. Good to see compound movements being promoted in a commercial gym environment. Prolly helps the new manager is an ex sprinter, who deadlifts close to 300 himself :)
Strangely similar to the comp we had on here - 1.5 x bodyweight for max reps. There were only 5 or 6 competitors unfortunately, so not much in the way of competition, but a few onlookers (~25) and decent prizes made up for it. Being a commercial gym, I took 1st place (tehe) and all the typical big gym bros were too scared to step up to the plate and even give it a go. Shame!
I pulled 120kg x 15 on first attempt and 12 reps for the second, 5 mins later. Really wanted to faint after the second lot! Grip held me back on the first set; the back and heart/lungs wanted to keep going, but the fingers said no. Gotta work on that. Still, that's 5 more reps than I did of the same weight in our comp on here...so I'm glad to see I've progressed.
Props to the fat 50 year old dude who pushed out 9 reps of 180kg...this kind of thing definitely favours the lean and lightweight.
thinking I either need to get more grip strength or some straps - since I'm plateauing on 100kg! Kept finding the bar wanted to slip out of my fingers, didn't help that my gym has no f**king ventilation or fans going in winter at all, making it extremely humid in there to the point that the condensation drips from the roof.
Chalk + mixed grip = instant +50kg grip capacity.
Other than that, there are grip strengthening exercises you can do...holding the lockout on last rep for example.
gym was going off tonight, dat open day full disco spec yo'
congrats birdmang on the win
was at work so couldn't do deadlift comp unfortunately :( wouldn't of won but at least done it
Your grip is weak. Keep doing deads and it will get stronger eventually. Then something else will lag. Use normal grip instead of mixed to help with developing the grip strength. Also focus on squeezing the hell out of your grip when you lift.
I had a feeling that this was part of it too - I've been trying to squeeze the crap out of all the weights when I use them to build it up some more
Was good to have good music in there for once haha.
Cheers mate. Shame you couldn't make it down; would have been good to have more lifters there. Said they were gonna run another comp later this month for a different lift. I got a $100 Coles Myer card for my efforts - not bad for just doing my workout!
Looking to post some good deadlift numbers during tomorrow's workout.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
