The regs said 95db limit, but they didn't have anything to test it. There were a couple of cars running screamers and I'm sure they would have been at least 110db LOL. You'd fit in fine ;P
Let me know when the next decent event is on and ill try make it down ;)
For sure man :D
There is an Esses Descent planned on the 30th March but not 100% sure if it will go ahead.
Hillclimb on Mountain Straight on 31st August, Supersprint on Conrod on 2nd November and again the 29th November as well as a Hillclimb on Mountain Straight again on the 30th November.
For sure man :D
Oh nice! Well ill have too pick the one that suits my car best :P Can i just do conrod by itself? :laugh:
Yea man, the Supersprints are just Conrod so you could just do one of those days. But I will insist that you do a hill climb as well man, would love to hear your car hitting gate all the way up the mountain :D
If they let me that is :P Would be keen to give it a crack :yes: I was pretty jelly once i knew you were there!
Well, when people say that Jim Berry likes to talk, they don't lie :P . I was on the phone to him for about an hour and a half total today, but I learnt a lot (and a lot passed right through one ear and out the other too! haha). I have now ordered a custom clutch and new flywheel from Jim himself. It is almost the same as what Mat (34GeeTeeTee) is running, a 6 puk solid single plate, except with 5000 clamp pressure. It is a bit overkill for my car currently but I am hoping that I will never have to replace it :) . Jim said he would get a start on it and give me a call back in a couple of days, so hopefully I'll get it sometime next week maybe then I can figure out exactly when I will be able to get help fitting it :P
Edited by timmy_89
Juts got a call from Jim to say he is sending the clutch/flywheel ^_^
Wow, he musnt of had too many phone calls today :ph34r:
(If he reads this i hope he laughs lol)...
Yeeep. Haha. Oh well, now I have some spare seals I guess :P
I know we had trouble getting the rear main seal right on mine, check it over and make sure it is 100% before fitting :yes:
He mentioned having trouble with the rear main, I'll line it before removing the old one and make sure it all looks right :)
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
