Finally got some spare time and started looking at my Defi's and trial fitting them.
I am going to attempt to leave the cups on them and get a thin bit of steel rod to put through the mounts to help with aligning them together easier, I'll post pics and let you know how it goes.
My first lot of deliveries for the week turned up.
Gearbox oil (Redline Lightweight Shockproof), all new seal kit, clutch alignment tool (which as I mentioned turns out I'll be getting with the clutch anyway haha :( ) and also a magnetic sump plug which I will chuck in next time I drop the engine oil.
Edited by timmy_89
So, I finally got around to fitting the Defi's this week. I'm still to fit the sensors, but the gauges themselves are in lol.
I tapped into the IGN power, ground and illumination from the cigarette lighter and then the constant power leading to the head unit for the control unit, thinking I will velcro it into the glove box but currently it is sitting in the passenger footwell lol.
I love how easy it is to pull shit apart in R34's lol.
Someone asked earlier to post pics on how I mounted these, so here it is, I siliconed them! Haha, looks a bit sketchy but I didn't want them falling back and silicon is easy enough to get off so I figured more was best lol.
Fitted up. Not 100% perfect alignment but you can't really tell.
With headlights on.
Edited by timmy_89
No boost gauge?
Nar, I have the e-boost to check if I need to (currently sitting in the glove box).
If I get another gauge I'll probably pillar mount it and whatever the other one is (only other one I can think I'd get would be AFR but that won't be until I do a bit more engine work).
I've still got a water temp gauge I want to hook up and have looked at AFR as well but as much as I want them in the car I dont want to go through the hassle of pillar mounting them only to get defected
Don't you have an AFR? :3
I don't see it as a necessity just a precautionary thing.
Yep in the glovebox out of sight! It is simply there for troubleshooting if anything goes wrong.... The Haltech protects the engine so no need to watch what its doing!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
