Finally got some spare time and started looking at my Defi's and trial fitting them.
I am going to attempt to leave the cups on them and get a thin bit of steel rod to put through the mounts to help with aligning them together easier, I'll post pics and let you know how it goes.
My first lot of deliveries for the week turned up.
Gearbox oil (Redline Lightweight Shockproof), all new seal kit, clutch alignment tool (which as I mentioned turns out I'll be getting with the clutch anyway haha :( ) and also a magnetic sump plug which I will chuck in next time I drop the engine oil.
Edited by timmy_89
So, I finally got around to fitting the Defi's this week. I'm still to fit the sensors, but the gauges themselves are in lol.
I tapped into the IGN power, ground and illumination from the cigarette lighter and then the constant power leading to the head unit for the control unit, thinking I will velcro it into the glove box but currently it is sitting in the passenger footwell lol.
I love how easy it is to pull shit apart in R34's lol.
Someone asked earlier to post pics on how I mounted these, so here it is, I siliconed them! Haha, looks a bit sketchy but I didn't want them falling back and silicon is easy enough to get off so I figured more was best lol.
Fitted up. Not 100% perfect alignment but you can't really tell.
With headlights on.
Edited by timmy_89
No boost gauge?
Nar, I have the e-boost to check if I need to (currently sitting in the glove box).
If I get another gauge I'll probably pillar mount it and whatever the other one is (only other one I can think I'd get would be AFR but that won't be until I do a bit more engine work).
I've still got a water temp gauge I want to hook up and have looked at AFR as well but as much as I want them in the car I dont want to go through the hassle of pillar mounting them only to get defected
Don't you have an AFR? :3
I don't see it as a necessity just a precautionary thing.
Yep in the glovebox out of sight! It is simply there for troubleshooting if anything goes wrong.... The Haltech protects the engine so no need to watch what its doing!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
