Hi, I am considering the v37 2009 model and understand from reading here that you can't get the navi working or maps for it here. I was looking at the Aus infiniti coupe and it looks to be visually the same navi unit. Has anyone checked the part number and cost of this unit so that it could just be retrofitted to the import and has anyone tried inserting the Aus spec dvd into the import to see if it will read it? Just curious if this is an option and have not seen it discussed.
I had someone in Sydney ring me in this today. It's NOT a direct swap.
You need to change:
Buttons
Controller for butttons,
screen
Navi control unit
Main radio button panel
and roughly $10k in cash.
Max,
tis fine . most people CBF'd reading and prefer to be spoon fed :-)l
  • 1 month later...
All I want is to disable the VSS wires on the foot ("hand") brake from disabling the AUX screen. My 2007 V36 Sedan has the AUX video and Audio inputs in the centre console, so using video out on a phone should be enough for us Navi owners ?
I have seen tutorials of the US car having the handbrake video disabled, but the wires are apparently diferent colours ?
  • 4 weeks later...
Im thinking of getting a v36 non navi for my next car. I am just wanting to know if the stereo is able to connect to an iPod properly and listen to fm radio via an expander and have it being usable? Thanks for any advice
The FM expander works regardless.
What do you mean when you say "work properly" in reference to your iPod? Are you talking about just line level/aux audio input or having full control of your iPod from the OEM stereo controls?
  • 2 months later...
  • 3 weeks later...
A quick note to those finding this in google.
Calling me , getting me to look at the car and then requesting all the part numbers to do the nav swap on a 2011 v36 because you think you can get the parts your self is outright rude. I am not a charity and I will not think twice about calling you out on it.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
