Congrats to squizz finally cracked 12s.. (bloody SMS woke me up :usuck: )
Known mods:
HKS panel filter
My old exhaust (2 x 2.5" frontpipe to 3" catback)
removed boost restrictor
previous owner had the car lowered
12.7@106mph 1.8s 60ft
https://www.sau.com.au/forums/topic/42206-squizzs-gtr-is-into-12s/
don't they do that stock? :)
i think you need these...
Been trying to sell these for a while on this forum have gone from $1800-$1500.
now i am lookign to have them gone for $1000 FIRM, cost me $2500 a year ago, and all they have done was sit in a box in the cuboard.
They are off a 1996 GTR V-spec that had around 45000km's. they are in excellent condition and come with dump pipes, O2 sensors, and manifolds. Ideal to twin turbo a VL, all that is needed is an adaptor plate as all of the exhaust ports match up.
I am short of money at the moment and the first person in with the money will get them. I don't want to be ****ed around, let me know and i'll get you my bank details asap, and send them off...
direct deposit only, $20 freight to anywhere and i'll pay thre rest. will be sent with registered/insured post.
Regards Nathan
p.s. will get pics up asap.
Congrats to Jay and Neil.
Had to leave early as I promised the missus I would be home by lunch.
Thanks for the invite Neil :)
I will have that cooler piping sorted by the end of the week and then hopefully do a full 1/4 mile :)
nothign quite beats the sight of a cooler pipe running its own 400m :D
damn hose clamps :D
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
